주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lasko CD08200 Control Panel Replacement
필요한 것
    1. Lasko CD08200 Control Panel Replacement, Lasko CD08200 Disassembly: 1 단계, 이미지 2개 중 1개 Lasko CD08200 Control Panel Replacement, Lasko CD08200 Disassembly: 1 단계, 이미지 2개 중 2개
      • Turn over the device and place it on its head.
      • Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
      댓글 쓰기
    2. Lasko CD08200 Control Panel Replacement: 2 단계, 이미지 1개 중 1개
      • Remove both 14mm screws from the power cord casing using a Phillips #2 screwdriver.
      • Remove the power cord casing from the device case.
      댓글 쓰기
    3. Lasko CD08200 Control Panel Replacement: 3 단계, 이미지 3개 중 1개 Lasko CD08200 Control Panel Replacement: 3 단계, 이미지 3개 중 2개 Lasko CD08200 Control Panel Replacement: 3 단계, 이미지 3개 중 3개
      • Cut the sticker on the right side of the device using a Jimmy.
      • Unscrew the four 14mm screws with a Phillips #2 bit on the back of the device.
      • If your screwdriver cannot reach the screw, you can use the metal spudger.
      • Remove the back casing from the device.
      댓글 쓰기
    4. Lasko CD08200 Control Panel Replacement: 4 단계, 이미지 3개 중 1개 Lasko CD08200 Control Panel Replacement: 4 단계, 이미지 3개 중 2개 Lasko CD08200 Control Panel Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the four 14mm screws housing the fan using the Phillips #2 screwdriver.
      • Remove the top of the fan housing with the fan attached and place it on the table.
      댓글 쓰기
    1. Lasko CD08200 Control Panel Replacement, Control Panel: 5 단계, 이미지 2개 중 1개 Lasko CD08200 Control Panel Replacement, Control Panel: 5 단계, 이미지 2개 중 2개
      • Unscrew the four rings using the Phillips #2.
      • Gently remove the fan base from the device.
      댓글 쓰기
    2. Lasko CD08200 Control Panel Replacement: 6 단계, 이미지 3개 중 1개 Lasko CD08200 Control Panel Replacement: 6 단계, 이미지 3개 중 2개 Lasko CD08200 Control Panel Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the four 14mm screws using the Phillips #2 screwdriver.
      • Gently detach the control panel from the device.
      댓글 쓰기
    3. Lasko CD08200 Control Panel Replacement: 7 단계, 이미지 2개 중 1개 Lasko CD08200 Control Panel Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the five 14mm screws using the Phillips #2 screwdriver.
      • Pull apart the motherboard from the panel.
      댓글 쓰기
    4. Lasko CD08200 Control Panel Replacement: 8 단계, 이미지 3개 중 1개 Lasko CD08200 Control Panel Replacement: 8 단계, 이미지 3개 중 2개 Lasko CD08200 Control Panel Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the three 10mm screws using the Phillips #2 screwdriver.
      • Pull the button from the panel’s top.
      • During reassembly of the top panel, you must align the LED light with the three windows of the top panel and back panel.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Najiib Ahmed
회원 가입일: 01/14/20
161 평판
안내서 1개를 작성함
York University, Team S1-G1, Woodhouse Winter 2020 York University, Team S1-G1, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G1
3 회원들
안내서 59개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 15
전체 시간: 1,175
