주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Le Pan S Speaker Replacement
필요한 것
    1. Le Pan S Speaker Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
      • This cover is adjacent to the volume button on the side of the Le Pan S.
      댓글 쓰기
    2. Le Pan S Speaker Replacement: 2 단계, 이미지 2개 중 1개 Le Pan S Speaker Replacement: 2 단계, 이미지 2개 중 2개
      • Insert the spudger between the front and back panel in order to pry them apart.
      • Do this beside the volume button and the micro SD cover.
      • Pry open the rest of the Le Pan S by dragging the spudger across the side.
      댓글 쓰기
    3. Le Pan S Speaker Replacement: 3 단계, 이미지 1개 중 1개
      • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
      댓글 쓰기
    4. Le Pan S Speaker Replacement: 4 단계, 이미지 2개 중 1개 Le Pan S Speaker Replacement: 4 단계, 이미지 2개 중 2개
      • Disconnect the battery from the circuitry and lay it out of the way.
      • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
      • If you are replacing your battery, make sure to dispose of it properly.
      댓글 쓰기
    1. Le Pan S Speaker Replacement, Speaker: 5 단계, 이미지 1개 중 1개
      • Remove the four 3.5 mm Phillips #00 screws holding the speakers in place.
      • Move the speakers out of the way.
      댓글 쓰기
    2. Le Pan S Speaker Replacement: 6 단계, 이미지 1개 중 1개
      • Place the wick on the solder connecting the speakers to the electrical board.
      • Place a heated soldering iron on the solder wick to melt the existing solder.
      • Pull the speakers off of the solder connection.
      • A solder vacuum can also be used in place of solder wick to remove old solder.
      • If you need more help with the soldering process, take a look at iFixit's guide for soldering and desoldering connections.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Maria Dole
회원 가입일: 09/17/15
395 평판
안내서 3개를 작성함
IUPUI, Team 2-1, Harley Fall 2015 IUPUI, Team 2-1, Harley Fall 2015 회원
IUPUI-HARLEY-F15S2G1
5 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 25
전체 시간: 512
