주요 콘텐츠로 건너뛰기
Lenovo Edge 15 LCD Screen Replacement
Gracie Harder
Gracie Harder2 다른 기여자
최종 수정일 January 2, 2018
20 - 30 분
조정
This guide will teach you to replace the LCD screen of your laptop computer.
필요한 것
도구
  1. Lenovo Edge 15 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1개 중 1개
    • Remove the black plastic or rubber screw caps covering screws, located at the bottom of the screen
  2. Lenovo Edge 15 LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Lenovo Edge 15 LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the (2) M2.5 × 2.5 mm, Black Phillips Nylok coated screws with the Phillips #1 screwdriver, located on either side of the bottom of the screen.
  3. Lenovo Edge 15 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Pry apart plastic cover at the bottom of the screen from plastic hinge cover.
  4. Lenovo Edge 15 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the (1) M2.5 x 2.5mm Black Phillips, Nylok coated screw located near the bottom center of the screen with the Phillips #1 screwdriver.
  5. Lenovo Edge 15 LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 Lenovo Edge 15 LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Slide LCD screen around the edges while pulling upwards so that it pops off.
    • Turn the screen over so the touch board is visible, and start working from the back of the screen.
    • Ribbons will be connected in the back of the screen, so be careful not to pull too far that they rip out.
  6. Lenovo Edge 15 LCD Screen Replacement: 6 단계, 이미지 2개 중 1개 Lenovo Edge 15 LCD Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Unplug the sensor from the sensor board near the bottom left of behind the screen.
  7. Lenovo Edge 15 LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Lenovo Edge 15 LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the two ribbons from connectors from the same board from the previous step, near the bottom left of the behind the screen.
    • The ribbon connectors unlatch by pulling up on the very small brown plastic bar near the end of the ribbon.
    • Be careful not to pull on the ribbons before unlatching. This may damage the connector and/or ribbons.
  8. Lenovo Edge 15 LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 Lenovo Edge 15 LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the tape covering a ribbon connector near the bottom of the screen.
    • Disconnect the ribbon by pulling back the small grey latch on the connector and gently pulling the ribbon away.
  9. Lenovo Edge 15 LCD Screen Replacement: 9 단계, 이미지 3개 중 1개 Lenovo Edge 15 LCD Screen Replacement: 9 단계, 이미지 3개 중 2개 Lenovo Edge 15 LCD Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Remove LCD screen by gently pulling screen away from the rest of the laptop.
    • Make sure all connections are secure when installing new screen. This eliminates the connection issue if screen is still not working properly after installation.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Gracie Harder
회원 가입일: 09/27/17
257 평판
안내서 1개를 작성함
Cal Poly, Team S8-G1, Banghart Fall 2017 Cal Poly, Team S8-G1, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G1
5 회원들
안내서 7개를 작성함
댓글 4개
Does the lcd separate from the digitizer screen or do both need to be replaced if the digitizer is cracked?
Sylvia Gagne - 답글
Typically one can separate the LCD from the glass, but it is a difficult and painful process, and it almost always cracks the LCD. If the cost is not prohibitively expensive, I would just replace them together as one unit.
Allan Wilson -
I need that exact bottom frame strip piece replaced that they are showing in the first picture. Does anyone know where I can order one?
Josselyn Santiago - 답글
looking to replace the whole screen, if possible even the hinge.
nasty bent screen I have for over 2+ years and I want to change that. Any advice welcomed.
frame is bent, Glass is broken in corner, touch screen gone.
Wouldnt care to install digitizer back but if I can see how to install screen components that be good.
Carry on.
Simarpreet Singh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 20
지난 30일: 60
전체 시간: 10,864
