주요 콘텐츠로 건너뛰기
Lenovo Legion Y7000P Battery Replacement
필요한 것
  1. Lenovo Legion Y7000P Battery Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 1/2 Lenovo Legion Y7000P Battery Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2/2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo Legion Y7000P Battery Replacement, Flip your laptop over: 2 단계, 이미지 1/1
    • Flip your laptop over so the rubber feet are facing up.
  3. Lenovo Legion Y7000P Battery Replacement, Unfasten the back cover: 3 단계, 이미지 1/2 Lenovo Legion Y7000P Battery Replacement, Unfasten the back cover: 3 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the 11 screws securing the back cover:
    • Five 11.5 mm‑long screws
    • Six 4.7 mm-long screws
  4. Lenovo Legion Y7000P Battery Replacement, Insert an opening pick: 4 단계, 이미지 1/2 Lenovo Legion Y7000P Battery Replacement, Insert an opening pick: 4 단계, 이미지 2/2
    • Insert the flat side of an opening pick between the top right corner of the back cover and frame.
  5. Lenovo Legion Y7000P Battery Replacement, Release the back cover's clips: 5 단계, 이미지 1/3 Lenovo Legion Y7000P Battery Replacement, Release the back cover's clips: 5 단계, 이미지 2/3 Lenovo Legion Y7000P Battery Replacement, Release the back cover's clips: 5 단계, 이미지 3/3
    • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
    • Keep the pick angled upwards while sliding to help release the clips.
    • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
  6. Lenovo Legion Y7000P Battery Replacement: 6 단계, 이미지 1/3 Lenovo Legion Y7000P Battery Replacement: 6 단계, 이미지 2/3 Lenovo Legion Y7000P Battery Replacement: 6 단계, 이미지 3/3
    • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
  7. Lenovo Legion Y7000P Battery Replacement, Remove the back cover: 7 단계, 이미지 1/3 Lenovo Legion Y7000P Battery Replacement, Remove the back cover: 7 단계, 이미지 2/3 Lenovo Legion Y7000P Battery Replacement, Remove the back cover: 7 단계, 이미지 3/3
    • Remove the back cover.
  8. Lenovo Legion Y7000P Battery Replacement, Reassembly information: 8 단계, 이미지 1/3 Lenovo Legion Y7000P Battery Replacement, Reassembly information: 8 단계, 이미지 2/3 Lenovo Legion Y7000P Battery Replacement, Reassembly information: 8 단계, 이미지 3/3
    • During reassembly:
    • Slide the two tabs near the center of the back cover's top edge under the hinge cover.
    • Press down firmly around the perimeter of the back cover to engage all the clips.
  9. Lenovo Legion Y7000P Battery Replacement, Heat the black cover: 9 단계, 이미지 1/2 Lenovo Legion Y7000P Battery Replacement, Heat the black cover: 9 단계, 이미지 2/2
    • A stiff, black cover runs across the heatsink and fans.
    • Removing the cover makes repairs much easier, but isn't required. If you don't want to remove the cover, you can roll it onto itself to keep it out of the way and skip the next two steps.
    • Heat an iOpener and apply it to the cover for two minutes.
    • You can also use a hair dryer. Follow this guide for more instructions.
  10. Lenovo Legion Y7000P Battery Replacement, Remove the cover: 10 단계, 이미지 1/3 Lenovo Legion Y7000P Battery Replacement, Remove the cover: 10 단계, 이미지 2/3 Lenovo Legion Y7000P Battery Replacement, Remove the cover: 10 단계, 이미지 3/3
    • Gently peel up and remove the black cover.
    • During reassembly, press the cover back into place using the residual adhesive.
  11. Lenovo Legion Y7000P Battery Replacement, Disconnect the battery: 11 단계, 이미지 1/3 Lenovo Legion Y7000P Battery Replacement, Disconnect the battery: 11 단계, 이미지 2/3 Lenovo Legion Y7000P Battery Replacement, Disconnect the battery: 11 단계, 이미지 3/3
    • Use the flat end of a spudger to push the battery connector straight out of its socket.
    • Push the tab on top of the battery connector, not the wires themselves.
  12. Lenovo Legion Y7000P Battery Replacement, Unfasten the battery: 12 단계, 이미지 1/2 Lenovo Legion Y7000P Battery Replacement, Unfasten the battery: 12 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the five 5.7 mm‑long screws securing the battery.
  13. Lenovo Legion Y7000P Battery Replacement, Remove the battery: 13 단계, 이미지 1/2 Lenovo Legion Y7000P Battery Replacement, Remove the battery: 13 단계, 이미지 2/2
    • Remove the battery.
결론
Check your repair by running hardware tests with Lenovo Diagnostics.
For optimal performance, calibrate your newly installed battery after completing this guide.
다른 2명이 해당 안내서를 완성하였습니다.
Spencer Day
회원 가입일: 09/14/22
54,989 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,303개 작성하였습니다
댓글 한 개
Worked great! My laptop looks a little different, and I didn’t have a black cover to worry about, but the essentials of this guide were super helpful.
DrP - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 21
30일 전: 49
전체 시간: 479
