주요 콘텐츠로 건너뛰기
Lenovo ThinkPad L440 Battery Replacement
Bobby Kennedy
Bobby Kennedy3 다른 기여자
최종 수정일 December 30, 2024
30 초
쉬움
Use this guide to replace a faulty battery in the Lenovo Thinkpad L440.
The battery is responsible for storing power so that you can move freely with your laptop. Signs of a failing battery can include your laptop dying quickly, or not being able to use your laptop unless you are plugged into an outside power source.
Before using this guide, check our troubleshooting page. In some cases, a quick draining battery can be caused by too many background applications, or malware. In both instances, the battery may not have to be replaced.
Batteries typically only last for 2-5 years, and will deteriorate over time and charging cycle. In this case, it may be a good idea to replace the battery to curb future issues.
Note: This guide does not require any tools.
필요한 것
부품
  1. Lenovo ThinkPad L440 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Lenovo ThinkPad L440 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Lenovo ThinkPad L440 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Open the laptop to access the power button.
    • Hold the power button in the top right until the computer powers off.
    • Turn the computer over so that the bottom of the computer is facing up
  2. Lenovo ThinkPad L440 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • On the left side under the raised surface, move the tab to the left towards the unlocked symbol. Repeat this on the right side and move the tab to the right towards the unlocked symbol.
  3. Lenovo ThinkPad L440 Battery Replacement: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad L440 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • From the top of the laptop, slide the raised surface away from the rest of the laptop and out of its slot to remove the battery from the computer.
결론
작성자
3다른 기여자 명과 함께
Bobby Kennedy
회원 가입일: 10/18/24
353 평판
안내서 2개를 작성함
UMass Dartmouth, Team 2-6, Konn Fall 2024 UMass Dartmouth, Team 2-6, Konn Fall 2024 회원
UMASSD-KONN-F24S2G6
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 19
지난 30일: 43
전체 시간: 119
