주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad T560 Fan Replacement
필요한 것
    1. Lenovo ThinkPad T560 Fan Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
      • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
      • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
      댓글 쓰기
    2. Lenovo ThinkPad T560 Fan Replacement: 2 단계, 이미지 1개 중 1개
      • Use the iFixit opening tool to pry the back panel off your T560.
      • Work your way around the perimeter of the device to undo the clips and detach the back panel.
      댓글 쓰기
    1. Lenovo ThinkPad T560 Fan Replacement, Battery: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad T560 Fan Replacement, Battery: 3 단계, 이미지 2개 중 2개
      • Disconnect the battery connector from the motherboard by pulling it out of the port.
      댓글 쓰기
    2. Lenovo ThinkPad T560 Fan Replacement: 4 단계, 이미지 1개 중 1개
      • Using the Phillips #0 screwdriver, remove the five 3.5 mm screws securing the battery.
      • Remove the battery.
      댓글 쓰기
    1. Lenovo ThinkPad T560 Fan Replacement, Fan: 5 단계, 이미지 3개 중 1개 Lenovo ThinkPad T560 Fan Replacement, Fan: 5 단계, 이미지 3개 중 2개 Lenovo ThinkPad T560 Fan Replacement, Fan: 5 단계, 이미지 3개 중 3개
      • Using the iFixit opening tool, unlatch the power button's connection to the motherboard.
      • Remove the ribbon cable from the connector.
      댓글 쓰기
    2. Lenovo ThinkPad T560 Fan Replacement: 6 단계, 이미지 1개 중 1개
      • Unplug the fan from the motherboard.
      댓글 쓰기
    3. Lenovo ThinkPad T560 Fan Replacement: 7 단계, 이미지 1개 중 1개
      • Using the Phillips #0 screwdriver, remove the four 3.5 mm screws securing the heatsink.
      댓글 쓰기
    4. Lenovo ThinkPad T560 Fan Replacement: 8 단계, 이미지 1개 중 1개
      • Using the Phillips #0 screwdriver, unscrew the 3.5mm screw securing the fan to the case.
      • Remove the fan and conjoined heatsink.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Jackson Reynolds
회원 가입일: 02/27/22
517 평판
안내서 5개를 작성함
Clemson, Team 1-3, Hunter Spring 2022 Clemson, Team 1-3, Hunter Spring 2022 회원
CLEM-HUNTER-S22S1G3
5 회원들
안내서 29개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 44
전체 시간: 1,737
