주요 콘텐츠로 건너뛰기
Lenovo ThinkPad W540 Hard Drive Replacement
Kevin Dang
Kevin Dang2 다른 기여자
최종 수정일 April 23, 2024
8 분
쉬움
추천 학생 안내서
Do your stored files appear corrupted for no reason? Does your laptop have a slow boot time? Then this guide should help you either replace the hard disk drive (HDD) or solid-state drive (SSD) installed within your device. Keep in mind that this device does not support SSDs with M.2. slots.
필요한 것
부품
도구
더보기...
  1. Lenovo ThinkPad W540 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad W540 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 2개
    • Flip the laptop to the bottom so the backplate is shown.
    • Use a Phillips #0 screwdriver to unscrew the 2 captive screws that secure the backplate.
    • These screws should hold on to the backplate even after removal. So, you shouldn't worry about losing them.
  2. Lenovo ThinkPad W540 Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad W540 Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to unscrew the single 3 mm screw that secures the hard drive.
  3. Lenovo ThinkPad W540 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Lift up the bottom half of the hard drive at a 25 degree angle.
    • Simply pull out the hard drive.
  4. Lenovo ThinkPad W540 Hard Drive Replacement: 4 단계, 이미지 3개 중 1개 Lenovo ThinkPad W540 Hard Drive Replacement: 4 단계, 이미지 3개 중 2개 Lenovo ThinkPad W540 Hard Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Safely remove the plastic guard surrounding both the hard drive and ESD shielding.
  5. Lenovo ThinkPad W540 Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 Lenovo ThinkPad W540 Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully removing the ESD shielding surrounding the hard drive.
    • Do not disregard the ESD shielding unless your new hard drive or SSD comes with its own shielding. Failure to do so will lead to severe damage to your device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kevin Dang
회원 가입일: 10/30/23
360 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-2, Konn Fall 2023 UMass Dartmouth, Team 3-2, Konn Fall 2023 회원
UMASSD-KONN-F23S3G2
3 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 35
전체 시간: 518
