주요 콘텐츠로 건너뛰기
Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement
Isaac
Isaac3 다른 기여자
최종 수정일 April 23, 2024
6 분
쉬움
If your laptop is unable to read or write into disks, even after you have checked that the disks themselves are not scratched or damaged, and that the drivers are up to date, then this guide should help replace the optical drive bay, or ODD for short.
Note that you should take out any disks still inside the drive bay before proceeding with this replacement guide.
필요한 것
부품
도구
더보기...
  1. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): 1 단계, 이미지 2개 중 2개
    • Turn your laptop over so the backplate is facing you.
    • Start with your Phillips #0 screwdriver and unscrew the 2 screws in each of the top corners of the backplate.
    • These screws should stay put on the backplate, and should not fall off.
  2. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 2 단계, 이미지 2개 중 2개
    • With your Phillips #00 screwdriver, simply remove the one 3mm screw on the upper left side.
  3. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 3 단계, 이미지 3개 중 1개 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 3 단계, 이미지 3개 중 2개 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the ODD by using a plastic opening tool to push the drive out of the side of the laptop.
    • Make sure to place the tool where we removed the screw holding the drive in place in Step 2.
  4. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: 4 단계, 이미지 1개 중 1개
    • Once the ODD has popped out, simply grab and pull out the drive bay.
결론
작성자
3다른 기여자 명과 함께
Isaac
회원 가입일: 10/30/23
205 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 UMass Dartmouth, Team 4-1, Shaddix Spring 2024 회원
UMASSD-SHADDIX-S24S4G1
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 33
전체 시간: 243
