주요 콘텐츠로 건너뛰기
Lenovo ThinkPad W540 Thermal Paste Replacement
Simeon Brankov
Simeon Brankov3 다른 기여자
최종 수정일 September 26, 2024
1 시간
조정
커뮤니티-기여 안내서
필요한 것
부품
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Lenovo ThinkPad W540 Thermal Paste Replacement, Opening the laptop: 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad W540 Thermal Paste Replacement, Opening the laptop: 1 단계, 이미지 2개 중 2개
    • Unscrew all screws holding the back panel in place and disconnect the battery.
    • Now is a good idea to upgrade the RAM and also the CPU if needed.
  2. Lenovo ThinkPad W540 Thermal Paste Replacement, Removing the keyboard: 2 단계, 이미지 3개 중 1개 Lenovo ThinkPad W540 Thermal Paste Replacement, Removing the keyboard: 2 단계, 이미지 3개 중 2개 Lenovo ThinkPad W540 Thermal Paste Replacement, Removing the keyboard: 2 단계, 이미지 3개 중 3개
    • Push up the plastic trim around the keyboard keys.
    • Remove the several little screws that hold the keyboard and disconnect it.
    • Disconnect every single connector that you see.
  3. Lenovo ThinkPad W540 Thermal Paste Replacement, Reaching the motherboard: 3 단계, 이미지 3개 중 1개 Lenovo ThinkPad W540 Thermal Paste Replacement, Reaching the motherboard: 3 단계, 이미지 3개 중 2개 Lenovo ThinkPad W540 Thermal Paste Replacement, Reaching the motherboard: 3 단계, 이미지 3개 중 3개
    • Remove the palmrest and disconnect the shown connectors.
    • Remove the 2 hidden screws that hold the display.
    • Remove all other screws.
  4. Lenovo ThinkPad W540 Thermal Paste Replacement, The insides: 4 단계, 이미지 1개 중 1개
    • Insert wisdom here.
  5. Lenovo ThinkPad W540 Thermal Paste Replacement, Changing the thermal paste: 5 단계, 이미지 2개 중 1개 Lenovo ThinkPad W540 Thermal Paste Replacement, Changing the thermal paste: 5 단계, 이미지 2개 중 2개
    • Unscrew the 7 screws holding the CPU heatsink and disconnect the fan.
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU. Also change the thermal pads.
    • Now is a good idea to upgrade the CPU if needed.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan. You can also open it to clean it from the inside.
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order 1 -> 7 to ensure even pressure. Dont forget to plug in the fan cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Simeon Brankov
회원 가입일: 11/08/20
7,180 평판
안내서 54개를 작성함
댓글 한 개
The guide skips steps
Pyry300 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 61
전체 시간: 2,516
