주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement
Eevee Murdock
Eevee Murdock2 다른 기여자
최종 수정일 June 3, 2024
8 - 10 분
쉬움
If your Lenovo ThinkPad X1 Carbon (2nd Gen) won’t turn on or last the full battery life, use this guide to replace the battery.
The battery stores the energy for your computer.
Before using this guide, check that your computer has been charged in a reliable outlet by trying multiple outlets. Also, try using multiple charging cords to make sure your cord isn’t broken.
Before you begin, make sure your computer is off and unplugged.
필요한 것
수리 키트
이 키트는 이 안내서를 완료하는데 필요한 모든 부품과 도구를 포함하고 있습니다.
부품
도구
더보기...
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Battery: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the battery by pulling it directly towards you.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Eevee Murdock
회원 가입일: 01/23/20
1,110 평판
안내서 6개를 작성함
Cal Poly, Team S18-G4, White Winter 2020 Cal Poly, Team S18-G4, White Winter 2020 회원
CPSU-WHITE-W20S18G4
4 회원들
안내서 9개를 작성함
댓글 4개
iFixit replacement battery is rejected by X1 Carbon gen2 chassis as not-genuine/unauthorized. Is there some additional step to getting the battery to be recognized/allowed? Something in the BIOS? Or is the battery faulty?
lenovo_battery - 답글
Any comments from @ifixit?
Martin Optilon - 답글
Hi there! Thanks for bringing this to our attention. @lenovo_battery, sorry to hear you're having trouble with your battery. Please reach out directly to our customer support team by emailing support@ifixit.com.
Kristen Gismondi -
Hi,
Great guide. I found that my screw heads were a bit stripped and the #0 driver was too small and bounced too much. The #1 driver worked better for me. Thanks for promoting the repair revolution! - MiLo
milostudios - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 25
지난 30일: 87
전체 시간: 5,752
