주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement
Diego Garcia reyes
Diego Garcia reyes3 다른 기여자
최종 수정일 April 12, 2024
30 - 50 분
조정
액션 샷
더 많은 이미지가 필요함
누락된 단계
This guide will show users how to replace the speakers on the Lenovo ThinkPad X1 Carbon 5th Gen, Type 20K3-S0DQ00 S/N PF-0VPYSA 1710. This will help users that are experiencing audio issues with their device. It will allow for an audio jack replacement as well as the speaker replacement because the two are connected. We recommend users attempt to clean the speaker/ audio jack first using compressed air before coming to this guide.
The device should be powered off and disconnected from the charger when working on the device.
필요한 것
부품
도구
더보기...
  1. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: 2 단계, 이미지 1개 중 1개
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: 4 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: 5 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: 5 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the battery using your hand or a prying tool.
  6. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: 6 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: 6 단계, 이미지 2개 중 2개
    • Use the Phillips #1 screwdriver to remove the two 1.2 mm screws.
  7. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: 7 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: 7 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: 7 단계, 이미지 3개 중 3개
    • Unplug the speaker cable from the board.
  8. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: 8 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: 8 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: 8 단계, 이미지 3개 중 3개
    • Lift up the marked latch and remove the cable.
    • Remove the speaker.
결론
You will have the speaker replaced and fully working. To reassemble your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Diego Garcia reyes
회원 가입일: 09/01/21
496 평판
안내서 5개를 작성함
Gateway, Team 1-3, Saknee Fall 2021 Gateway, Team 1-3, Saknee Fall 2021 회원
GCC-SAKNEE-F21S1G3
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 61
전체 시간: 1,181
