주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X1 Extreme Trackpad Replacement
Ryleigh Jenkins
Ryleigh Jenkins4 다른 기여자
최종 수정일 March 20, 2024
6 - 10 분
쉬움
누락된 단계
This guide will lead you through the steps to replace the trackpad on the Lenovo ThinkPad X1 Extreme Generation 1. The trackpad is used to control the device and may get worn down with age.
The removal of the trackpad requires you to first remove the battery, then proceed to remove four screws. Make sure the device is turned off before you begin these steps.
필요한 것
부품
도구
더보기...
  1. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Speakers: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Trackpad Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Battery: 4 단계, 이미지 3개 중 1개 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Battery: 4 단계, 이미지 3개 중 2개 Lenovo ThinkPad X1 Extreme Trackpad Replacement, Battery: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Extreme Trackpad Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the battery out of the frame and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Trackpad Replacement, Trackpad: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Flathead 1.5 mm Screwdriver
    $5.49
    • Remove the four screws that are holding the trackpad to the Thinkpad using a 1.5 mm flathead screwdriver.
  7. Lenovo ThinkPad X1 Extreme Trackpad Replacement: 7 단계, 이미지 2개 중 1개 Lenovo ThinkPad X1 Extreme Trackpad Replacement: 7 단계, 이미지 2개 중 2개
    • Use a spudger to release the retaining tab on the trackpad cable connector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 36
전체 시간: 1,862
