주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement
Lex
Lex5 다른 기여자
최종 수정일 January 30, 2025
40 - 55 분
조정
If your Lenovo ThinkPad Yoga 11e Gen 6 has a broken screen, it may make it difficult to see the display properly. A cracked laptop screen is a serious injury hazard, as shards of broken glass may cut you or become imbedded into your skin. This guide will demonstrate how to safely replace the broken screen.
필요한 것
부품
도구
더보기...
  1. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
    • Wearing the anti-static wrist strap will prevent a static shock from damaging the components in the laptop.
    • Disconnect the laptop from power and make sure it is completely powered off.
    • Turn the laptop facing down.
    • Loosen the eight captive screws using a JIS #0 screwdriver.
    • The screws are attached to the panel and cannot be removed.
    • Carefully remove the panel.
  2. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: 2 단계, 이미지 3개 중 1개 Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: 2 단계, 이미지 3개 중 2개 Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Carefully disconnect the two sliding connectors in the left and right corner.
    • Disconnect the sliding connector on the Wi-Fi board.
    • Loosen the four 9.7 mm screws on the hinges in the top left and right corners using a Phillips #0 screwdriver.
    • Carefully lift the closest part of the laptop away from the screen side of the laptop.
  3. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: 3 단계, 이미지 3개 중 1개 Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: 3 단계, 이미지 3개 중 2개 Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Using tweezers, gently pry and remove the covers on the LCD strip.
    • Remove the two 3.3 mm screws that were previously under the covers on the LCD strip using a Phillips #0 screwdriver.
    • Carefully lift and remove the LCD strip.
  4. Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: 4 단계, 이미지 3개 중 1개 Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: 4 단계, 이미지 3개 중 2개 Lenovo ThinkPad Yoga 11e Gen 6 Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the two 3.3 mm screws from the silver panels using a Phillips #0 screwdriver.
    • Remove the two 3.3 mm screws from the LCD panel using a Phillips #0 screwdriver.
    • Carefully lift the screen towards you. You may use the spudger to assist lifting the screen. There will be one more connector on the side of the screen.
    • Carefully remove the ribbon connectors by gently pulling with your fingers.
결론
작성자
5다른 기여자 명과 함께
Lex
회원 가입일: 10/02/24
509 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 21
지난 30일: 40
전체 시간: 112
