주요 콘텐츠로 건너뛰기
Lenovo V14-ADA Screen Replacement
Samaya Roukoz
Samaya Roukoz4 다른 기여자
최종 수정일 June 25, 2024
20 분
조정
If your Lenovo V14-ADA (model 82C60072UE) has some dead pixels on the screen or the screen just wont work, you can use this guide to replace the LCD panel (screen). Dead pixels on the laptop are often displayed as a small black or white dot that can be caused by manufacturing defects or physical damage.
Before beginning, make sure the laptop is unplugged and turned off because the steps require disassembling parts of the laptop. Proceed with caution while completing the process in this guide.
필요한 것
도구
  1. Lenovo V14-ADA Screen Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down.
  2. Lenovo V14-ADA Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all ten 5 mm screws from the back panel using a JIS #0 screwdriver.
  3. Lenovo V14-ADA Screen Replacement: 3 단계, 이미지 2개 중 1개 Lenovo V14-ADA Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Place the Jimmy in the small crack between the back panel and the keyboard and push down.
    • Repeat this until the panel pops off.
  4. Lenovo V14-ADA Screen Replacement, Battery: 4 단계, 이미지 2개 중 1개 Lenovo V14-ADA Screen Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Remove the four 3 mm screws surrounding the battery using a JIS #0 screwdriver.
    • Slightly pull on the black wire connector to unplug the battery.
    • Lift up the battery to remove it from the laptop.
  5. Lenovo V14-ADA Screen Replacement, Screen: 5 단계, 이미지 3개 중 1개 Lenovo V14-ADA Screen Replacement, Screen: 5 단계, 이미지 3개 중 2개 Lenovo V14-ADA Screen Replacement, Screen: 5 단계, 이미지 3개 중 3개
    • Remove the four 3 mm screws on the hinges on both sides of the back of the laptop.
    • Use the Jimmy to pop the surrounding screen bezel off.
  6. Lenovo V14-ADA Screen Replacement: 6 단계, 이미지 2개 중 1개 Lenovo V14-ADA Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the two 3 mm screws at the top two corners of the screen using a JIS #0 screwdriver.
  7. Lenovo V14-ADA Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the screen from the laptop.
결론
작성자
4다른 기여자 명과 함께
Samaya Roukoz
회원 가입일: 03/19/24
253 평판
안내서 3개를 작성함
UMass Dartmouth, Team 4-2, Shaddix Spring 2024 UMass Dartmouth, Team 4-2, Shaddix Spring 2024 회원
UMASSD-SHADDIX-S24S4G2
5 회원들
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 15
전체 시간: 173
