주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo V14-IIL Camera Replacement
필요한 것
    1. Lenovo V14-IIL Camera Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Lenovo V14-IIL Camera Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
      • Make sure the laptop is powered off and unplug all cables before beginning any repair.
      • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
      • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
      • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
      댓글 쓰기
    2. Lenovo V14-IIL Camera Replacement: 2 단계, 이미지 1개 중 1개
      • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
      • You may need to move the tool to different locations to fully release the back cover.
      댓글 쓰기
    3. Lenovo V14-IIL Camera Replacement: 3 단계, 이미지 1개 중 1개
      • Lift away the back panel and set it aside.
      댓글 쓰기
    1. Lenovo V14-IIL Camera Replacement, Display Assembly: 4 단계, 이미지 2개 중 1개 Lenovo V14-IIL Camera Replacement, Display Assembly: 4 단계, 이미지 2개 중 2개
      • Using a Phillips #0 screwdriver, remove the four 5 mm screws from the hinges of the laptop.
      댓글 쓰기
    2. Lenovo V14-IIL Camera Replacement: 5 단계, 이미지 1개 중 1개
      • Lift up the latch and gently pull the display cable free.
      댓글 쓰기
    3. Lenovo V14-IIL Camera Replacement: 6 단계, 이미지 2개 중 1개 Lenovo V14-IIL Camera Replacement: 6 단계, 이미지 2개 중 2개
      • Using the spudger, disconnect the two wireless LAN cables (black and gray) from the wireless LAN card.
      • Remove the LAN cables from the three brackets on the fan.
      댓글 쓰기
    4. Lenovo V14-IIL Camera Replacement: 7 단계, 이미지 1개 중 1개
      • Ensure that all cables and hinges are detached.
      • Lift the display assembly away from the base.
      댓글 쓰기
    1. Lenovo V14-IIL Camera Replacement, Screen Bezel: 8 단계, 이미지 2개 중 1개 Lenovo V14-IIL Camera Replacement, Screen Bezel: 8 단계, 이미지 2개 중 2개
      • Slide the cable hinge cover to the right.
      • Pull the part away from the screen.
      댓글 쓰기
    2. Lenovo V14-IIL Camera Replacement: 9 단계, 이미지 2개 중 1개 Lenovo V14-IIL Camera Replacement: 9 단계, 이미지 2개 중 2개
      • Use the iFixit opening tool to separate the bezel panel.
      • Slide the opening tool all the way around to loosen the bezels on all sides.
      • You may need to use the tool to gently loosen the adhesive tape.
      • Lift away the bezel panel.
      댓글 쓰기
    1. Lenovo V14-IIL Camera Replacement, Camera: 10 단계, 이미지 1개 중 1개
      • Gently pull out the stretch adhesive tape.
      • Make sure to pull from hinges to the top of the LCD panel.
      • You may need to use the metal spudger to help loosen the adhesive.
      댓글 쓰기
    2. Lenovo V14-IIL Camera Replacement: 11 단계, 이미지 1개 중 1개
      • Disconnect the wire from the back of the integrated camera and lift the camera away.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sydney Askins
회원 가입일: 01/16/24
402 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 29
전체 시간: 486
