주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Levoit Core 300-RAC Power Cord Replacement
필요한 것
    1. Levoit Core 300-RAC Power Cord Replacement, Air Filter: 1 단계, 이미지 2개 중 1개 Levoit Core 300-RAC Power Cord Replacement, Air Filter: 1 단계, 이미지 2개 중 2개
      • Make sure your device is turned off and unplugged for safety.
      • Turn the Levoit Core 300-RAC over so the bottom is facing up.
      댓글 쓰기
    2. Levoit Core 300-RAC Power Cord Replacement: 2 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Power Cord Replacement: 2 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Power Cord Replacement: 2 단계, 이미지 3개 중 3개
      • Turn the bottom cover counterclockwise and lift it off to remove it.
      • The cover does not "snap" on or off when turned.
      댓글 쓰기
    3. Levoit Core 300-RAC Power Cord Replacement: 3 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Power Cord Replacement: 3 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Power Cord Replacement: 3 단계, 이미지 3개 중 3개
      • Lift the filter straight up and out of the device.
      댓글 쓰기
    1. Levoit Core 300-RAC Power Cord Replacement, Power Cord: 4 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Power Cord Replacement, Power Cord: 4 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Power Cord Replacement, Power Cord: 4 단계, 이미지 3개 중 3개
      • Use a Phillips #2 screwdriver to remove the four screws that go through the four white tabs inside the device
      • Set the screws aside in a safe place.
      댓글 쓰기
    2. Levoit Core 300-RAC Power Cord Replacement: 5 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Power Cord Replacement: 5 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Power Cord Replacement: 5 단계, 이미지 3개 중 3개
      • Use a metal spudger to gently pry between the four white tabs and the white housing and release the outer housing.
      • Gently pull up on the outer housing to prevent the clips from resetting.
      댓글 쓰기
    3. Levoit Core 300-RAC Power Cord Replacement: 6 단계, 이미지 2개 중 1개 Levoit Core 300-RAC Power Cord Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the white outer housing and set it to the side.
      • The power cord is fed through a hole in the side of this housing, so it will need to be right next to the rest of the device.
      댓글 쓰기
    4. Levoit Core 300-RAC Power Cord Replacement: 7 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Power Cord Replacement: 7 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Power Cord Replacement: 7 단계, 이미지 3개 중 3개
      • Grab the cable channel by its base, squeeze, and pull up at the same time to remove it.
      댓글 쓰기
    5. Levoit Core 300-RAC Power Cord Replacement: 8 단계, 이미지 2개 중 1개 Levoit Core 300-RAC Power Cord Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the four Phillips #2 screws securing the gray face plate.
      댓글 쓰기
    6. Levoit Core 300-RAC Power Cord Replacement: 9 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Power Cord Replacement: 9 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Power Cord Replacement: 9 단계, 이미지 3개 중 3개
      • Insert a Jimmy or spudger between the white tab and the gray faceplate body to release the faceplate.
      • Lift it out.
      댓글 쓰기
    7. Levoit Core 300-RAC Power Cord Replacement: 10 단계, 이미지 1개 중 1개
      • Use wire cutters to carefully cut off the crimped power cord connections and remove the white power cord.
      • Cut as close to the connection as possible to leave as much of the internal wires as possible.
      • Cut your new power cable to length and replace the old one. You can splice the new cable on using a soldering iron, heat shrink tubing, and a heat gun. Alternatively, you can use twist-on wire nuts to make a secure connection. For more information on soldering, take a look at How to Solder and Desolder Connectors, and How to Use Heat Shrink Tubing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
David Kamp
회원 가입일: 11/02/23
589 평판
안내서 3개를 작성함
UMass Dartmouth, Team 1-6, Petersen Fall 2023 UMass Dartmouth, Team 1-6, Petersen Fall 2023 회원
UMASSD-PETERSEN-F23S1G6
5 회원들
안내서 8개를 작성함
2가이드 댓글
You're a lifesaver, thank you! My rabbit managed to reach the cable for mine and chewed it up, my allergies have been going crazy
Grace - 답글 공유
What type of cable did you use to replace the older one?
Mauricio Diaz - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 19
지난 30일: 95
전체 시간: 3,271
