주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lexibook Junior Tablet Charging Port Replacement
필요한 것
    1. Lexibook Junior Tablet Charging Port Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Make sure your device is powered off before replacement to prevent electric shock.
      • With the device screen face down, use the metal spudger to remove the small rubber circles on all four corners of the device. The screws should now be revealed.
      • Using the metal spudger, pry open the small, long rubber rectangle on the back of the device to reveal more screws.
      댓글 쓰기
    2. Lexibook Junior Tablet Charging Port Replacement: 2 단계, 이미지 1개 중 1개
      • Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
      • Using the same screwdriver, remove the three screws that were behind the rubber rectangle. These screws do not come out of the device.
      • Use the plastic opening tool to gently pry open the back panel of the tablet.
      댓글 쓰기
    3. Lexibook Junior Tablet Charging Port Replacement: 3 단계, 이미지 1개 중 1개
      • Use the nylon spudger to gently pry under the battery to remove it.
      • Make sure you do not damage the battery or metal plate in this process and only use a nylon spudger. Be patient and work slowly for the best results.
      댓글 쓰기
    4. Lexibook Junior Tablet Charging Port Replacement: 4 단계, 이미지 1개 중 1개
      • Use a soldering iron to remove the battery from the motherboard safely.
      • For advice on how to solder, check out iFixit's Soldering Guide.
      댓글 쓰기
    1. Lexibook Junior Tablet Charging Port Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 Lexibook Junior Tablet Charging Port Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
      • Using the plastic opening tool, gently push the two small, black and white switches out in the direction of the ribbon wires.
      • Slowly pull the ribbon wire out of the switch to free it.
      댓글 쓰기
    2. Lexibook Junior Tablet Charging Port Replacement: 6 단계, 이미지 1개 중 1개
      • Push the larger black and white strip leading to a ribbon wire upward using the plastic opening tool.
      • Carefully pull the ribbon wire out of the switch
      댓글 쓰기
    3. Lexibook Junior Tablet Charging Port Replacement: 7 단계, 이미지 3개 중 1개 Lexibook Junior Tablet Charging Port Replacement: 7 단계, 이미지 3개 중 2개 Lexibook Junior Tablet Charging Port Replacement: 7 단계, 이미지 3개 중 3개
      • Unscrew the five 4 mm screws around the perimeter of the motherboard using the ph00 size phillips head screwdriver.
      댓글 쓰기
    4. Lexibook Junior Tablet Charging Port Replacement: 8 단계, 이미지 2개 중 1개 Lexibook Junior Tablet Charging Port Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the button board by unscrewing two more 4 mm screws and one 6.5 mm screw
      댓글 쓰기
    5. Lexibook Junior Tablet Charging Port Replacement: 9 단계, 이미지 1개 중 1개
      • Solder off connections from the wire connecting the motherboard to the speaker.
      • For how to solder, check out iFixit's Soldering Guide.
      댓글 쓰기
    1. Lexibook Junior Tablet Charging Port Replacement, Charging Port: 10 단계, 이미지 2개 중 1개 Lexibook Junior Tablet Charging Port Replacement, Charging Port: 10 단계, 이미지 2개 중 2개
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Rachel Klesius
회원 가입일: 09/19/16
645 평판
안내서 6개를 작성함
USF Tampa, Team 17-3, Blackwell Fall 2016 USF Tampa, Team 17-3, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S17G3
4 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 33
전체 시간: 991
