주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Linksys EA9200 Power Switch Replacement
필요한 것
    1. Linksys EA9200 Power Switch Replacement, Linksys EA9200 Disassembly: 1 단계, 이미지 2개 중 1개 Linksys EA9200 Power Switch Replacement, Linksys EA9200 Disassembly: 1 단계, 이미지 2개 중 2개
      • Remove the sticker on the bottom.
      • Remove the two screws holding the bottom plate in place. Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
      댓글 쓰기
    2. Linksys EA9200 Power Switch Replacement: 2 단계, 이미지 2개 중 1개 Linksys EA9200 Power Switch Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the back sticker that has all the labels.
      • There are two screws to remove. They are 6mm in diameter, use phillips screw tip #1.
      댓글 쓰기
    3. Linksys EA9200 Power Switch Replacement: 3 단계, 이미지 3개 중 1개 Linksys EA9200 Power Switch Replacement: 3 단계, 이미지 3개 중 2개 Linksys EA9200 Power Switch Replacement: 3 단계, 이미지 3개 중 3개
      • Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage.
      댓글 쓰기
    4. Linksys EA9200 Power Switch Replacement: 4 단계, 이미지 3개 중 1개 Linksys EA9200 Power Switch Replacement: 4 단계, 이미지 3개 중 2개 Linksys EA9200 Power Switch Replacement: 4 단계, 이미지 3개 중 3개
      • Once you have one side open, keep a spudger wedged between both sides. This will help keep it open in case it tries to snap back together.
      • These clips are tough and may need some additional force.
      댓글 쓰기
    5. Linksys EA9200 Power Switch Replacement: 5 단계, 이미지 3개 중 1개 Linksys EA9200 Power Switch Replacement: 5 단계, 이미지 3개 중 2개 Linksys EA9200 Power Switch Replacement: 5 단계, 이미지 3개 중 3개
      • Lift the board and pull down, away from the antennas.
      댓글 쓰기
    1. Linksys EA9200 Power Switch Replacement, Power Switch: 6 단계, 이미지 3개 중 1개 Linksys EA9200 Power Switch Replacement, Power Switch: 6 단계, 이미지 3개 중 2개 Linksys EA9200 Power Switch Replacement, Power Switch: 6 단계, 이미지 3개 중 3개
      • Desolder the 7 pins for the power switch from the backside of the circuit board.
      • In order to remove this part you will need a soldering iron that is capable of reaching temperatures greater than 300 degrees Fahrenheit.
      • 연결부 납땜 및 납제거 방법 is iFixit's official guide on how to use a soldering iron.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Shane Davis
회원 가입일: 10/05/16
374 평판
안내서 3개를 작성함
USF Tampa, Team 9-1, Lacy Fall 2016 USF Tampa, Team 9-1, Lacy Fall 2016 회원
USFT-LACY-F16S9G1
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 24
전체 시간: 786
