주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Liquid Damage Technique
필요한 것
    1. Liquid Damage Technique, Top Casing: 1 단계, 이미지 1개 중 1개
      • Power down and unplug the device.
      댓글 쓰기
    2. Liquid Damage Technique: 2 단계, 이미지 1개 중 1개
      댓글 쓰기
    3. Liquid Damage Technique: 3 단계, 이미지 1개 중 1개
      • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
      댓글 쓰기
    4. Liquid Damage Technique: 4 단계, 이미지 1개 중 1개
      • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
      댓글 쓰기
    5. Liquid Damage Technique: 5 단계, 이미지 1개 중 1개
      • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
      • This may require a bit of force.
      댓글 쓰기
    6. Liquid Damage Technique: 6 단계, 이미지 1개 중 1개
      • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
      댓글 쓰기
    7. Liquid Damage Technique: 7 단계, 이미지 2개 중 1개 Liquid Damage Technique: 7 단계, 이미지 2개 중 2개
      • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
      댓글 쓰기
    8. Liquid Damage Technique: 8 단계, 이미지 2개 중 1개 Liquid Damage Technique: 8 단계, 이미지 2개 중 2개
      • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
      • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
      • Once the top panel is removed the main board will still be attached to the bottom panel.
      댓글 쓰기
    1. Liquid Damage Technique, Bottom Casing/Motherboard: 9 단계, 이미지 2개 중 1개 Liquid Damage Technique, Bottom Casing/Motherboard: 9 단계, 이미지 2개 중 2개
      • Unscrew the two screws that connect the motherboard to the bottom casing.
      • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
      댓글 쓰기
    1. Liquid Damage Technique, Liquid Damage Technique: 10 단계, 이미지 1개 중 1개
      • If the spilled substance is dry use a cleaning tool such as a toothbrush with soft bristles, so you do not damage the device, to brush off as much of the foreign material as possible.
      댓글 쓰기
    2. Liquid Damage Technique: 11 단계, 이미지 1개 중 1개
      • Dry off circuit board with kitchen paper; using other types of paper products such as toilet paper will fall apart. Be sure not to rub but carefully apply pressure to dry up wet spots.
      댓글 쓰기
    3. Liquid Damage Technique: 12 단계, 이미지 1개 중 1개
      • Clean off the components to make sure the rest of the residue comes off by using a chemical gasoline or another solvent that contains one substance that evaporates quickly.
      댓글 쓰기
결론
After the device is cleaned and put back together it should work properly.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Derek Myers
회원 가입일: 10/04/11
288 평판
안내서 5개를 작성함
Cal Poly, Team 21-21, Maness Fall 2011 Cal Poly, Team 21-21, Maness Fall 2011 회원
CPSU-MANESS-F11S21G21
5 회원들
안내서 51개를 작성함
1가이드 댓글
I did all of this still not working it gets hot only but doesn’t turn it on.
DM MG - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 44
전체 시간: 7,805
