주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lite-On iHAS324 Eject Button and Power LED Light Replacement
필요한 것
    1. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Chassis: 1 단계, 이미지 2개 중 1개 Lite-On iHAS324 Eject Button and Power LED Light Replacement, Chassis: 1 단계, 이미지 2개 중 2개
      • Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
      • There may be resistance, do not be afraid to use force.
      • The tray should then pop open.
      • Pull out the tray so that it is fully extended.
      댓글 쓰기
    2. Lite-On iHAS324 Eject Button and Power LED Light Replacement: 2 단계, 이미지 3개 중 1개 Lite-On iHAS324 Eject Button and Power LED Light Replacement: 2 단계, 이미지 3개 중 2개 Lite-On iHAS324 Eject Button and Power LED Light Replacement: 2 단계, 이미지 3개 중 3개
      • Use a plastic opening tool to push the three tabs located on the right, left, and bottom side of the outer chassis to loosen the faceplate off.
      댓글 쓰기
    3. Lite-On iHAS324 Eject Button and Power LED Light Replacement: 3 단계, 이미지 1개 중 1개
      • Pull the faceplate off the chassis.
      • Do NOT pull the faceplate all the way off the disc tray, because doing so can cause damage to the faceplate.
      댓글 쓰기
    4. Lite-On iHAS324 Eject Button and Power LED Light Replacement: 4 단계, 이미지 1개 중 1개
      • Using the Phillips Head #2 screwdriver, unscrew the two 8.5 mm screws located on the bottom back of the chassis.
      댓글 쓰기
    5. Lite-On iHAS324 Eject Button and Power LED Light Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the bottom plate by lifting it off the device.
      댓글 쓰기
    6. Lite-On iHAS324 Eject Button and Power LED Light Replacement: 6 단계, 이미지 1개 중 1개
      • Turn the device over.
      • Remove the top plate by pulling the sides and lifting the plate off.
      댓글 쓰기
    1. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Disc Tray: 7 단계, 이미지 2개 중 1개 Lite-On iHAS324 Eject Button and Power LED Light Replacement, Disc Tray: 7 단계, 이미지 2개 중 2개
      • Push the left tab in and slide the tray out on the left side.
      • Pull the gray plastic casing on the right side away from the tray.
      • Slide the right side of the tray out.
      댓글 쓰기
    1. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Disc Tray Belt: 8 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Take tweezers and remove the black tray belt from the gears carefully.
      댓글 쓰기
    1. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Eject Button and Power LED Light: 9 단계, 이미지 1개 중 1개
      • Flip the device over.
      댓글 쓰기
    2. Lite-On iHAS324 Eject Button and Power LED Light Replacement: 10 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to pull all three tabs, lifting up the circuit board as you go.
      댓글 쓰기
    3. Lite-On iHAS324 Eject Button and Power LED Light Replacement: 11 단계, 이미지 1개 중 1개
      • Carefully lift the circuit board out of the plastic casing.
      댓글 쓰기
    4. Lite-On iHAS324 Eject Button and Power LED Light Replacement: 12 단계, 이미지 1개 중 1개
      • Using a solder wick, unsolder either the eject button or Power LED Light. Soldering Guide
      • Then, using a solder iron, replace them.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kayla Culpepper
회원 가입일: 03/22/15
726 평판
안내서 5개를 작성함
Baylor, Team 5-9, Williams Spring 2015 Baylor, Team 5-9, Williams Spring 2015 회원
BU-WILLIAMS-S15S5G9
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 49
전체 시간: 1,338
