주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G X56 HOTAS Throttle LED Board Replacement
필요한 것
  1. Logitech G X56 HOTAS Throttle LED Board Replacement, Label Plate: 1 단계, 이미지 2개 중 1개 Logitech G X56 HOTAS Throttle LED Board Replacement, Label Plate: 1 단계, 이미지 2개 중 2개
    • Remove the eight 8.6 mm long 1.5 mm hex screws from the label plate.
    댓글 쓰기
  2. Logitech G X56 HOTAS Throttle LED Board Replacement: 2 단계, 이미지 1개 중 1개
    • Use an opening tool to pry off the mode switch knob.
    댓글 쓰기
  3. Logitech G X56 HOTAS Throttle LED Board Replacement: 3 단계, 이미지 3개 중 1개 Logitech G X56 HOTAS Throttle LED Board Replacement: 3 단계, 이미지 3개 중 2개 Logitech G X56 HOTAS Throttle LED Board Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the eight 12.5 mm long Phillips #1 screws from the underside of the label plate.
    • These screws are plastic! Be very careful when applying force.
    댓글 쓰기
  4. Logitech G X56 HOTAS Throttle LED Board Replacement: 4 단계, 이미지 2개 중 1개 Logitech G X56 HOTAS Throttle LED Board Replacement: 4 단계, 이미지 2개 중 2개
    • Place the throttle right side up again, using the bottom panel as a coaster.
    • Gently pry the label plate from the body of the throttle.
    댓글 쓰기
  5. Logitech G X56 HOTAS Throttle LED Board Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 Logitech G X56 HOTAS Throttle LED Board Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Optional: Take a picture or mark each connector as you remove them for ease of reassembly.
    • Disconnect all of the motherboard connectors by pulling them straight up and out of their sockets.
    댓글 쓰기
  6. Logitech G X56 HOTAS Throttle LED Board Replacement: 6 단계, 이미지 2개 중 1개 Logitech G X56 HOTAS Throttle LED Board Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the four 11.6 mm-long Phillips #0 screws that secure the motherboard.
    댓글 쓰기
  7. Logitech G X56 HOTAS Throttle LED Board Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the motherboard from the base plate shell, carefully making sure to keep the USB power cable unstrained.
    댓글 쓰기
  8. Logitech G X56 HOTAS Throttle LED Board Replacement, LED Board: 8 단계, 이미지 2개 중 1개 Logitech G X56 HOTAS Throttle LED Board Replacement, LED Board: 8 단계, 이미지 2개 중 2개
    • Each LED Board uses the LEDs to hold it against the base plate. It also has a single cable set to the logic and power board.
    댓글 쓰기
  9. Logitech G X56 HOTAS Throttle LED Board Replacement: 9 단계, 이미지 2개 중 1개 Logitech G X56 HOTAS Throttle LED Board Replacement: 9 단계, 이미지 2개 중 2개
    • Each of the LEDs needs to be removed with a soldering iron and your choice of solder wick or solder sucker.
    • Once free of the solder, the LED must be pushed through to the front.
    댓글 쓰기
  10. Logitech G X56 HOTAS Throttle LED Board Replacement: 10 단계, 이미지 1개 중 1개
    • Gently Remove the LED board.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Elizabeth Matlock-Buchanan
회원 가입일: 02/22/25
842 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 34
전체 시간: 339
