주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G522 Lightspeed Ear Pads Replacement
    1. Logitech G522 Lightspeed Ear Pads Replacement, Prepare the headset for disassembly: 1 단계, 이미지 2개 중 1개 Logitech G522 Lightspeed Ear Pads Replacement, Prepare the headset for disassembly: 1 단계, 이미지 2개 중 2개
      • Power off the headset and unplug all cables.
      댓글 쓰기
    1. Logitech G522 Lightspeed Ear Pads Replacement, Remove the ear pads: 2 단계, 이미지 3개 중 1개 Logitech G522 Lightspeed Ear Pads Replacement, Remove the ear pads: 2 단계, 이미지 3개 중 2개 Logitech G522 Lightspeed Ear Pads Replacement, Remove the ear pads: 2 단계, 이미지 3개 중 3개
      • With one hand, firmly hold an ear cup steady.
      • With your free hand, slowly pull the ear pad away from the cup until it slides completely off its plastic lip.
      • Repeat the process to remove the other ear pad.
      댓글 쓰기
    2. Logitech G522 Lightspeed Ear Pads Replacement, Install an ear pad: 3 단계, 이미지 3개 중 1개 Logitech G522 Lightspeed Ear Pads Replacement, Install an ear pad: 3 단계, 이미지 3개 중 2개 Logitech G522 Lightspeed Ear Pads Replacement, Install an ear pad: 3 단계, 이미지 3개 중 3개
      • Installing an ear pad onto the cup can be tricky. Be patient and work slowly—it may take a couple tries.
      • To put an ear pad onto its cup:
      • With your free hand, place the pad over the top of the cup, so the fabric flap slips over the cup's plastic lip.
      • Thread the rest of the flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
      • Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
344,889 평판
안내서 915개를 작성함
1가이드 댓글
Where can you buy the earpad replacement for the G522 Lightspeed Headset? Can't seem to find it anywhere! Thanks!
kingjulian - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 41
지난 30일: 157
전체 시간: 1,920
