주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G705 Battery Replacement
필요한 것
  1. Logitech G705 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Logitech G705 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the skate pads from the bottom of the mouse by peeling them off to access the screws.
    • If you plan on reusing these skates, you can use a hair dryer or heat gun to soften the adhesive and gently remove the skates.
    댓글 쓰기
  2. Logitech G705 Battery Replacement: 2 단계, 이미지 3개 중 1개 Logitech G705 Battery Replacement: 2 단계, 이미지 3개 중 2개 Logitech G705 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips #000 screwdriver to remove the four 5.0 mm screws securing the bottom of the mouse shell.
    • It's recommended to use a parts tray to store these small screws, so you do not lose them.
    댓글 쓰기
  3. Logitech G705 Battery Replacement: 3 단계, 이미지 3개 중 1개 Logitech G705 Battery Replacement: 3 단계, 이미지 3개 중 2개 Logitech G705 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Carefully pry the two halves of the mouse shell apart.
    • Be careful, as ribbon cables run along the edges.
    • Use a plastic pry tool if needed.
    댓글 쓰기
  4. Logitech G705 Battery Replacement: 4 단계, 이미지 2개 중 1개 Logitech G705 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Use the point of a plastic spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the battery connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • This step requires some force and may damage the plastic on the connector.
    댓글 쓰기
  5. Logitech G705 Battery Replacement: 5 단계, 이미지 2개 중 1개 Logitech G705 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the 3.0 mm PH000 screw from the black plastic bracket that secures the battery.
    • Remove the bracket.
    • The battery may come loose during this step, depending on the strength and amount of adhesive used during assembly. This is perfectly normal, and you may skip step 6 if this occurs.
    댓글 쓰기
  6. Logitech G705 Battery Replacement: 6 단계, 이미지 2개 중 1개 Logitech G705 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • If the battery did not come out, it may be easier to remove if the top and bottom of the mouse are separated first.
    • To separate the top and bottom of the mouse, use a spudger or a clean fingernail to flip up the locking flaps on the two ZIF connectors.
    • Use tweezers or your fingers to gently pull the ribbon cables straight out of their sockets.
    댓글 쓰기
  7. Logitech G705 Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the battery from the shell.
    • If the battery doesn't come out easily, use adhesive remover to loosen the adhesive and then safely remove the battery from the shell.
    • Do not use a metal pry tool or pry the battery, as doing so may damage or puncture it and cause injury.
    댓글 쓰기
  8. Logitech G705 Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Place the new battery with the adhesive back in the shell.
    • If the new battery does not have adhesive already, you may use double sided tape to hold it in place.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Carmen Chavez
회원 가입일: 02/23/26
81 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 65
전체 시간: 100
