주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech Harmony 650 Screen Replacement
필요한 것
    1. Logitech Harmony 650 Screen Replacement, Case: 1 단계, 이미지 2개 중 1개 Logitech Harmony 650 Screen Replacement, Case: 1 단계, 이미지 2개 중 2개
      • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
      댓글 쓰기
    2. Logitech Harmony 650 Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the batteries using the silver pull tab.
      댓글 쓰기
    3. Logitech Harmony 650 Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
      댓글 쓰기
    4. Logitech Harmony 650 Screen Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
      댓글 쓰기
    5. Logitech Harmony 650 Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
      댓글 쓰기
    6. Logitech Harmony 650 Screen Replacement: 6 단계, 이미지 2개 중 1개 Logitech Harmony 650 Screen Replacement: 6 단계, 이미지 2개 중 2개
      • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
      • The top led protector plastic cover will also be freed once back is removed.
      댓글 쓰기
    7. Logitech Harmony 650 Screen Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the rear cover.
      댓글 쓰기
    1. Logitech Harmony 650 Screen Replacement, Motherboard: 8 단계, 이미지 2개 중 1개 Logitech Harmony 650 Screen Replacement, Motherboard: 8 단계, 이미지 2개 중 2개
      • Using a J0 screwdriver remove the three 5mm screws holding the motherboard to the front face. Two are located just below the processor in the middle of the device and the third is located at the very bottom.
      댓글 쓰기
    2. Logitech Harmony 650 Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the motherboard by gently pulling it away from the case.
      댓글 쓰기
    1. Logitech Harmony 650 Screen Replacement, Screen: 10 단계, 이미지 2개 중 1개 Logitech Harmony 650 Screen Replacement, Screen: 10 단계, 이미지 2개 중 2개
      • Remove the black rubber gasket that surrounds the screen from the top face of the motherboard.
      • The gasket has 3 tabs along each side. The thick side of the gasket faces the top.
      댓글 쓰기
    2. Logitech Harmony 650 Screen Replacement: 11 단계, 이미지 1개 중 1개
      • Use a soldering iron to loosen the solder that connects the screen strip to the back of the motherboard. If it does not loosen easily then try using a soldering remover wick.
      • The soldering iron gets extremely hot use caution when using it around components.
      댓글 쓰기
    3. Logitech Harmony 650 Screen Replacement: 12 단계, 이미지 1개 중 1개
      댓글 쓰기
    4. Logitech Harmony 650 Screen Replacement: 13 단계, 이미지 1개 중 1개
      • Use a spudger or your hand to remove the screen from the motherboard. It is glued down.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Connor Gallagher
회원 가입일: 01/11/16
1,036 평판
안내서 5개를 작성함
2가이드 댓글
Hey will beat buy honor a warrenty
antonioofficial - 답글 공유
so where can i buy the screen!!!!
shortemperd Gotico - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 35
전체 시간: 3,285
