주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech M100 Switch Replacement
필요한 것
    1. Logitech M100 Switch Replacement, Switches: 1 단계, 이미지 1개 중 1개
      • Disconnect the mouse from any devices before attempting to remove any parts or starting the repair.
      • Flip your mouse over so the bottom is facing up.
      댓글 쓰기
    2. Logitech M100 Switch Replacement: 2 단계, 이미지 1개 중 1개
      • Use a small Phillips #00 screwdriver to remove the single screw at the bottom of the mouse.
      댓글 쓰기
    3. Logitech M100 Switch Replacement: 3 단계, 이미지 2개 중 1개 Logitech M100 Switch Replacement: 3 단계, 이미지 2개 중 2개
      • Turn your mouse over so it is facing right side up.
      • Use a spudger or your hands to carefully separate the top from the bottom housing.
      • It's important to remove the top housing while leaving the bottom in place, as the scroll wheel and other internal components may fall out otherwise.
      댓글 쓰기
    4. Logitech M100 Switch Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the external cable from the slot at the front of the mouse.
      댓글 쓰기
    5. Logitech M100 Switch Replacement: 5 단계, 이미지 3개 중 1개 Logitech M100 Switch Replacement: 5 단계, 이미지 3개 중 2개 Logitech M100 Switch Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the circuit board from the mouse by pushing down at the back and lifting up at the front.
      댓글 쓰기
    6. Logitech M100 Switch Replacement: 6 단계, 이미지 2개 중 1개 Logitech M100 Switch Replacement: 6 단계, 이미지 2개 중 2개
      • Lift the scroll wheel from the board.
      • There should be a total of four parts that make up the scroll wheel.
      댓글 쓰기
    7. Logitech M100 Switch Replacement: 7 단계, 이미지 1개 중 1개
      • Pull the USB cable away from the connector in the same direction as the individual wires to remove it from the motherboard.
      • This step may prove difficult with just your hands. Use a spudger if you need to.
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      댓글 쓰기
    8. Logitech M100 Switch Replacement: 8 단계, 이미지 1개 중 1개
      • Find a suitable method to hold the circuit board in place so you don't have to hold it in your hands.
      • Use a small vice to keep it in place or helping hands for this next step.
      댓글 쓰기
    9. Logitech M100 Switch Replacement: 9 단계, 이미지 3개 중 1개 Logitech M100 Switch Replacement: 9 단계, 이미지 3개 중 2개 Logitech M100 Switch Replacement: 9 단계, 이미지 3개 중 3개
      • Use a soldering iron to heat the solder points securing both switches, and remove the switches using tweezers.
      • The soldering iron and the solder holding the switch in place will be very hot and can burn you.
      댓글 쓰기
    10. Logitech M100 Switch Replacement: 10 단계, 이미지 3개 중 1개 Logitech M100 Switch Replacement: 10 단계, 이미지 3개 중 2개 Logitech M100 Switch Replacement: 10 단계, 이미지 3개 중 3개
      • Replace each switch and solder it to the circuit board.
      • The soldering wire may conduct heat up to the hand holding it.
      • Be sure to work in a well ventilated space as the solder may emit smoke.
      • You can use tape to hold the switch in place while soldering.
      댓글 쓰기
    11. Logitech M100 Switch Replacement: 11 단계, 이미지 2개 중 1개 Logitech M100 Switch Replacement: 11 단계, 이미지 2개 중 2개
      • Reassemble the mouse by following steps 2-7 in reverse order.
      댓글 쓰기
결론
Congratulations, you have now replaced the clickers on your mouse and can continue using it!
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Diego De La Fuente
회원 가입일: 03/05/24
211 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 62
전체 시간: 1,154
