주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech UE Megaboom 4 Battery Replacement
필요한 것
  1. Logitech UE Megaboom 4 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Logitech UE Megaboom 4 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Logitech UE Megaboom 4 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Flip your speaker upside down so the charging port side is faced upwards.
    • Take a metal spudger in between the rubber bottom and the mesh case.
    • Work your way around the base of the speaker until the top separates from the case of the speaker.
    • This will take force.
    • Use the metal spudger carefully. Improper use may lead to injury.
    댓글 쓰기
  2. Logitech UE Megaboom 4 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the bottom of the speaker and place it off to the side.
    • Once the glued seal is broken you will be able to pull it off with your hands.
    댓글 쓰기
  3. Logitech UE Megaboom 4 Battery Replacement: 3 단계, 이미지 3개 중 1개 Logitech UE Megaboom 4 Battery Replacement: 3 단계, 이미지 3개 중 2개 Logitech UE Megaboom 4 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Push with your thumbs on the two plastic pieces on the inside of your speaker.
    • The inside components will begin to slide out of the top from the mesh casing.
    댓글 쓰기
  4. Logitech UE Megaboom 4 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • The case and internal components of your speaker should now be separated.
    댓글 쓰기
  5. Logitech UE Megaboom 4 Battery Replacement: 5 단계, 이미지 3개 중 1개 Logitech UE Megaboom 4 Battery Replacement: 5 단계, 이미지 3개 중 2개 Logitech UE Megaboom 4 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the battery out with your fingers.
    • When pulling the battery out, you may need to wiggle it a little bit or use a rubber grip on your fingers.
    댓글 쓰기
  6. Logitech UE Megaboom 4 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • When installing the new battery, ensure that the battery connector aligns with the connector on the speaker so they don't get damaged.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Konner Buchal
회원 가입일: 02/03/25
470 평판
안내서 3개를 작성함
2가이드 댓글
ifixt it doesn't have the battery replacement version for the Ultimate Ears - MEGABOOM 4 and only show replacement battery for older model and I think this get confuse for new users in the repair world
Gio Ortegini - 답글 공유
Hi Gio,
Thanks for pointing this out! We’ve removed the link to the incorrect battery and appreciate your help keeping the guide accurate.
Sarah Westberg - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 20
지난 30일: 84
전체 시간: 1,044
