주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech UE Megaboom 4 Charging Port Replacement
필요한 것
    1. Logitech UE Megaboom 4 Charging Port Replacement, Outer Case: 1 단계, 이미지 3개 중 1개 Logitech UE Megaboom 4 Charging Port Replacement, Outer Case: 1 단계, 이미지 3개 중 2개 Logitech UE Megaboom 4 Charging Port Replacement, Outer Case: 1 단계, 이미지 3개 중 3개
      • Flip your speaker upside down so the charging port side is faced upwards.
      • Place the end of a metal spudger in between the rubber bottom and the mesh case.
      • Work your way around the base of the speaker until the top separates from the case of the speaker.
      • This will take force.
      • Use the metal spudger carefully. Improper use may lead to injury.
      댓글 쓰기
    2. Logitech UE Megaboom 4 Charging Port Replacement: 2 단계, 이미지 1개 중 1개
      • Pull the bottom end of the speaker off and place it aside.
      • Once the glued seal is broken you will be able to pull it off with your hands.
      댓글 쓰기
    3. Logitech UE Megaboom 4 Charging Port Replacement: 3 단계, 이미지 3개 중 1개 Logitech UE Megaboom 4 Charging Port Replacement: 3 단계, 이미지 3개 중 2개 Logitech UE Megaboom 4 Charging Port Replacement: 3 단계, 이미지 3개 중 3개
      • Use your thumbs to press the two plastic tabs inside the speaker case and gently push out the internal components.
      • The inside components will begin to slide out of the top from the mesh casing.
      댓글 쓰기
    4. Logitech UE Megaboom 4 Charging Port Replacement: 4 단계, 이미지 1개 중 1개
      • The internal components of the Logitech UE MegaBoom 4 speaker are now separated from the outer case.
      댓글 쓰기
    1. Logitech UE Megaboom 4 Charging Port Replacement, Charging Port: 5 단계, 이미지 1개 중 1개
      • Remove the cover from the USB-C charging port end of the device.
      • The port should be visible from the outside.
      댓글 쓰기
    2. Logitech UE Megaboom 4 Charging Port Replacement: 6 단계, 이미지 3개 중 1개 Logitech UE Megaboom 4 Charging Port Replacement: 6 단계, 이미지 3개 중 2개 Logitech UE Megaboom 4 Charging Port Replacement: 6 단계, 이미지 3개 중 3개
      • Use a Phillips #1 screwdriver to remove the two screws securing the I/O board inside the speaker's end cover.
      • Set the screws aside for reassembly.
      • Remove the black plastic bracket from the top of the I/O board.
      댓글 쓰기
    3. Logitech UE Megaboom 4 Charging Port Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the board with the charging port from the inside cover.
      • Take note of the charging port placement for reassembly.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Konner Buchal
회원 가입일: 02/03/25
470 평판
안내서 3개를 작성함
2가이드 댓글
Hi, where dit you find the replacement?
Greets
siemen van camp - 답글 공유
Same question here, wehre did you find the charging board replacement?
cheers
bohemianmarine1 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 36
전체 시간: 388
