주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech Webcam Pro 9000 Motherboard Replacement
필요한 것
  1. Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: 1 단계, 이미지 2개 중 1개 Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: 1 단계, 이미지 2개 중 2개
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
    댓글 쓰기
  2. Logitech Webcam Pro 9000 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Logitech Webcam Pro 9000 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
    댓글 쓰기
  3. Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: 3 단계, 이미지 3개 중 1개 Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: 3 단계, 이미지 3개 중 2개 Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: 3 단계, 이미지 3개 중 3개
    • Grasp the white connector attaching the button chip wire to the motherboard.
    • Grab between the tabs and the socket.
    • Wiggle the connector back and forth to remove it from the connection box
    • Do not worry if you detach the red and black wire connection on the power button.
    댓글 쓰기
  4. Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: 4 단계, 이미지 2개 중 1개 Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: 4 단계, 이미지 2개 중 2개
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
    댓글 쓰기
  5. Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: 5 단계, 이미지 2개 중 1개 Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to grasp the white wire connector on the back of the motherboard.
    • Wiggle the connector back and forth to remove it from the socket.
    댓글 쓰기
  6. Logitech Webcam Pro 9000 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Logitech Webcam Pro 9000 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Desolder the joint on the front of the motherboard to completely detach the USB cable.
    • Follow this link to learn how to properly solder and desolder your parts.
    댓글 쓰기
  7. Logitech Webcam Pro 9000 Motherboard Replacement, Camera: 7 단계, 이미지 1개 중 1개
    • Remove the two 8mm Phillips#0 screws on the back of the motherboard.
    댓글 쓰기
  8. Logitech Webcam Pro 9000 Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Logitech Webcam Pro 9000 Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Logitech Webcam Pro 9000 Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the camera from the motherboard by desoldering the two connections as shown.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Cory Davis
회원 가입일: 04/14/13
236 평판
안내서 4개를 작성함
Cal Poly, Team 12-34, Amido Spring 2013 Cal Poly, Team 12-34, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G34
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 48
전체 시간: 2,616
