Mac Mini Mid 2010 Cowling Replacement
예상시간 없음
조정
Use this guide to remove the small molded plastic cowl used to direct cool air toward the heat sink.
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
거의 끝나갑니다!
결론
다른 6명이 해당 안내서를 완성하였습니다.
