주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Air 11" Mid 2011 Solid-State Drive Replacement
필요한 것
    1. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Before proceeding, close your computer and lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
      댓글 쓰기
    2. MacBook Air 11" Mid 2011 Solid-State Drive Replacement: 2 단계, 이미지 1개 중 1개
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      댓글 쓰기
    1. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Battery: 3 단계, 이미지 2개 중 1개 MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Battery: 3 단계, 이미지 2개 중 2개
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
      댓글 쓰기
    1. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Solid-State Drive: 4 단계, 이미지 1개 중 1개
      • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
      댓글 쓰기
    2. MacBook Air 11" Mid 2011 Solid-State Drive Replacement: 5 단계, 이미지 2개 중 1개 MacBook Air 11" Mid 2011 Solid-State Drive Replacement: 5 단계, 이미지 2개 중 2개
      • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
      • Do not lift the end of the SSD excessively.
      • Pull the drive straight out of its socket and remove it from the logic board.
      • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 117명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Walter Galan
710,476 평판
안내서 1,203개를 작성함
16가이드 댓글
Note: if you're installing a blank SSD, you'll want to format it with Disk Utilities) before the OS X installer will recognize it.
aaronmiller - 답글 공유
Could not have been any easier, with this guide.
Thank you very much!
916sp - 답글 공유
is it possible to replace an 128 GB Solid State Drive with an 240 GB? (MacBook Air, 11", Mid 2011)
zimmermatthias - 답글 공유
Does anyone know if the Samsung 960 pro 512gb m.2 drive is compatible with this machine?
Mark - 답글 공유
No, is not, I just bought a 1TB Samsung 960 EVO m.2 and had to return it, for not being compatible. (is smaller and the pin-out is not the same)
fjlbandeira - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 26
지난 7일: 99
지난 30일: 320
전체 시간: 257,173
