소개
Use this guide to replace the microphone array assembly in a Late 2020 MacBook Air (M1).
To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure. A charged lithium-ion battery can be very dangerous if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Do not reuse the battery if it is swollen or was deformed in any way during the procedure. The battery is likely damaged and can be very dangerous to reuse—it should be replaced.
This guide involves removing the speakers and battery. You will need new adhesive to properly reinstall the speakers and battery.
필요한 것
이 단계에 사용된 도구:Magnetic Project Mat$19.95
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.3 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
Slide the pointed end of a spudger underneath the right speaker cable and pry straight up to disconnect it from the audio board.
Use a T3 Torx driver to remove the 4.2 mm screw securing the right speaker to the case.
Use a pair of tweezers to peel back the black pull tab on the speaker's stretch-release adhesive until you can grip it with your fingers.
Grab the adhesive strip's pull tab and slowly pull the adhesive strip out from underneath the speaker.
Pull the adhesive strip until it's freed from under the speaker.
Apply heat to the speaker to soften the adhesive underneath.
Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
이 단계에 사용된 도구:Tesa 61395 Tape$5.99
Remove the right speaker.
Slide the pointed end of a spudger underneath the left speaker cable and pry straight up to disconnect it from the logic board.
Use a T3 Torx driver to remove the 4.2 mm screw securing the left speaker to the case.
Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad cable cover.
Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
Use a T3 Torx driver to remove the two 2.6 mm screws securing the battery tray to the case.
On the left side of the MacBook, use a pair of tweezers to peel back the three black pull tabs on the battery's stretch-release adhesive strips until you can grip them with your fingers.
Remove the battery assembly.
Charge it to 100%, and keep charging it for at least 2 more hours.
Unplug and use it normally to drain the battery.
When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery.
Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
Use a pair of tweezers to peel back the tape covering the microphone cable connector.
Use the pointed end of a spudger to lift up the small locking flap on the microphone cable's ZIF connector.
Once you've completed your repair, your laptop may not power back on until connected to power.
다른 4명이 해당 안내서를 완성하였습니다.
