소개
Use this guide to replace the upper case of the 2019 MacBook Air, including the keyboard. This involves removing all the parts in the MacBook and transferring them to a new upper case. Make sure to keep track of screws and small parts so that they can be easily reinstalled in the new upper case.
Due to overlapping prerequisite guides, there are some repeated steps and inconsistencies in the photos. These are expected and do not effect the procedure. If you notice a repeated step, skip it and continue with the procedure.
To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure. A charged lithium-ion battery can be very dangerous if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Do not reuse the battery if it is swollen or was deformed in any way during the procedure. The battery is likely damaged and can be very dangerous to reuse—it should be replaced.
This guide involves removing the speakers and battery. You will need new adhesive to reinstall the speakers and battery.
필요한 것
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
이 단계에 사용된 도구:Tweezers$4.99
Use a pair of tweezers to lift up the black adhesive pull tab at the bottom of the right speaker, enough so you can grab it with your fingers.
Grab the adhesive strip pull tab and slowly and carefully pull the adhesive strip out from under the speaker.
If the adhesive strip breaks, leave it in and proceed to the next step.
Use tweezers to lift the adhesive pull tab at the top of the right speaker enough that you can grab it with your fingers.
Apply heat to the speaker to soften the adhesive underneath.
Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
Use a pair of tweezers to lift up the black adhesive pull tab at the bottom of the left speaker, enough so you can grab it with your fingers.
Use tweezers to lift the adhesive pull tab at the top of the left speaker enough that you can grab it with your fingers.
Slide the tip of a spudger underneath the speaker cable and pry straight up to disconnect the speaker.
Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board cable bracket.
Remove the cable bracket.
Remove the following screws:
Two 4.3 mm, T5 Torx screws
One 2.4 mm, T3 Torx screw
Slide an opening pick under the audio board cable to slice through the adhesive securing it to the fan.
Use a T3 Torx driver to remove the two 1.4 mm screws securing the antenna cable bracket.
Remove the antenna cable bracket.
Lift the antenna bar straight up and out of the case. Take care not to snag the antenna bar on any cables or connectors.
Remove the antenna bar.
Use a T9 Torx driver to remove the six 4.9 mm screws securing the display hinges to the upper case.
Use a T3 Torx driver to remove the six 1.6 mm screws securing the Touch ID sensor and its bracket.
Remove the Touch ID bracket.
Use a T3 Torx driver to remove the two 1.4 mm screws securing the USB-C connector bracket.
Remove the USB-C connector bracket.
Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad connector bracket.
Remove the trackpad connector bracket.
Use a spudger to lift up the small locking flap on the sound board cable's ZIF connector.
Slide the sound board cable out of the ZIF connector.
Use a T5 Torx driver to remove the following screws:
One 5.5 mm screw
Three 2.6 mm screws
Two 1.9 mm screws
Carefully slide an opening pick under the trackpad cable to separate the adhesive securing it to the upper case.
Use the flat end of a spudger to lift the small locking flap on the trackpad ZIF connector.
Slide the trackpad cable straight out of its connector.
Carefully slide an opening pick under the trackpad cable to separate the adhesive securing it to the battery.
Use a T5 Torx driver to remove the following screws securing the trackpad:
One 3.2 mm screw
Eight 3.1 mm screws
Use the flat end of a spudger to lift the small locking flap on the trackpad's ZIF connector.
Slide the trackpad cable straight out of the ZIF connector.
Use a T3 Torx driver to remove four 2.5 mm screws securing the battery.
Use a pair of tweezers to lift up the black adhesive pull tab on the side of the battery, enough so you can grab it with your fingers.
Grab the adhesive strip pull tab and slowly and carefully pull the adhesive strip out from under the battery.
Repeat the previous two steps to remove the three adhesive strips on the other side of the battery.
Carefully drip isopropyl alcohol along either edge of the battery, in the recessed part of the upper case, where the adhesive pull tabs were.
Let the alcohol soak into the adhesive for a minute or two.
Use opening picks to gently pry the battery away from the upper case.
Remove the battery.
Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
Slide an opening pick under the microphone farthest away from the edge of the case to slice through the adhesive securing it to the upper case.
Use a P2 pentalobe driver to remove the two 1.1 mm screws securing the USB-C port brackets.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
Saw one for cheap with a bad keyboard and battery. I think I'm gonna pass lmao
When reassembling the device, what does one do about all of the removed adhesive? Is it reusable, or is there some kind of recommended replacement material?
