주요 콘텐츠로 건너뛰기
MacBook Air Models A1237 and A1304 Heat Sink Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. MacBook Air Models A1237 and A1304 Heat Sink Replacement, Lower Case: 1 단계, 이미지 1/1
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
  2. MacBook Air Models A1237 and A1304 Heat Sink Replacement: 2 단계, 이미지 1/2 MacBook Air Models A1237 and A1304 Heat Sink Replacement: 2 단계, 이미지 2/2
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Air Models A1237 and A1304 Heat Sink Replacement, Battery: 3 단계, 이미지 1/1
    • Disconnect the battery connector by pulling it straight out of its socket.
  4. MacBook Air Models A1237 and A1304 Heat Sink Replacement: 4 단계, 이미지 1/1
    • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
  5. MacBook Air Models A1237 and A1304 Heat Sink Replacement: 5 단계, 이미지 1/1
    • Lift the battery out of the Air.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air Models A1237 and A1304 Heat Sink Replacement, Hard Drive: 6 단계, 이미지 1/3 MacBook Air Models A1237 and A1304 Heat Sink Replacement, Hard Drive: 6 단계, 이미지 2/3 MacBook Air Models A1237 and A1304 Heat Sink Replacement, Hard Drive: 6 단계, 이미지 3/3
    • Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
    • Pull the audio out ribbon cable off the adhesive securing it to the upper case.
    • Use a spudger to pry the audio out ribbon cable connector board off the hard drive bracket.
  7. MacBook Air Models A1237 and A1304 Heat Sink Replacement: 7 단계, 이미지 1/1
    • Disconnect the audio out cable from its socket on the port hatch ribbon cable.
  8. MacBook Air Models A1237 and A1304 Heat Sink Replacement: 8 단계, 이미지 1/1
    • Use a spudger to pry the hard drive cable connector up off the logic board.
  9. MacBook Air Models A1237 and A1304 Heat Sink Replacement: 9 단계, 이미지 1/2 MacBook Air Models A1237 and A1304 Heat Sink Replacement: 9 단계, 이미지 2/2
    • Use the sharp end of a spudger to de-route the microphone cable from the hard drive bracket.
    • Remove the cosmetic screw cover from the adhesive securing it to the hard drive bracket.
  10. MacBook Air Models A1237 and A1304 Heat Sink Replacement: 10 단계, 이미지 1/1
    • Remove the four Phillips screws securing the hard drive assembly to the upper case:
    • Two 4.7 mm screws.
    • Two 3.9 mm screws.
  11. MacBook Air Models A1237 and A1304 Heat Sink Replacement: 11 단계, 이미지 1/1
    • Lift the hard drive assembly out of the upper case.
  12. MacBook Air Models A1237 and A1304 Heat Sink Replacement, Heat Sink: 12 단계, 이미지 1/1
    • Use the tip of a spudger to pull the fan cable connector straight away from its connector on the logic board.
  13. MacBook Air Models A1237 and A1304 Heat Sink Replacement: 13 단계, 이미지 1/2 MacBook Air Models A1237 and A1304 Heat Sink Replacement: 13 단계, 이미지 2/2
    • Use the tip of a spudger to move the cosmetic fan cover aside.
  14. MacBook Air Models A1237 and A1304 Heat Sink Replacement: 14 단계, 이미지 1/2 MacBook Air Models A1237 and A1304 Heat Sink Replacement: 14 단계, 이미지 2/2
    • If you have the original version of the MacBook Air (A1237), refer to picture 1. Remove the following screws securing the heat sink to the logic board:
    • One 5.9 mm Phillips screw.
    • Two 1.9 mm Phillips screws.
    • One 1.9 mm Phillips screw.
    • If you have the A1304 version of MacBook Air, refer to picture 2. Remove the following screws securing the heat sink to the logic board:
    • One 5.0 mm Phillips screw
    • Five 1.9 mm Philips screws.
    • One 2.5 mm Phillips screw.
  15. MacBook Air Models A1237 and A1304 Heat Sink Replacement: 15 단계, 이미지 1/1
    • Lift the processor clamp off the heat sink.
  16. MacBook Air Models A1237 and A1304 Heat Sink Replacement: 16 단계, 이미지 1/1
    • Deroute the microphone cable away from the channel in the fan.
  17. MacBook Air Models A1237 and A1304 Heat Sink Replacement: 17 단계, 이미지 1/1
    • Lift the heat sink up off the logic board.
    • Be mindful of the microphone cable when lifting the heat sink, as it can get tangled on the top edge of the fan.
    • When you mount the heat sink back onto the logic board, be sure to apply a new layer of thermal paste. We have a guide that makes replacing the thermal paste easy.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Walter Galan
694,850 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 3,678
