주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook Core Duo Optical Drive Replacement
필요한 것
동영상 개요
  1. MacBook Core Duo Optical Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
    댓글 쓰기
  2. MacBook Core Duo Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery out of the computer.
    댓글 쓰기
  3. MacBook Core Duo Optical Drive Replacement, Memory Cover: 3 단계, 이미지 1개 중 1개
    • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover.
    • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
    댓글 쓰기
  4. MacBook Core Duo Optical Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
    댓글 쓰기
  5. MacBook Core Duo Optical Drive Replacement, Upper Case: 5 단계, 이미지 1개 중 1개
    • Remove the following 3 screws:
    • One 11 mm Phillips #00 in the middle of the case.
    • Two 14.5 mm Phillips #00.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle.
    댓글 쓰기
  6. MacBook Core Duo Optical Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
    • One 4 mm Phillips #00 on the right side.
    • When reinstalling these screws, press gently on the lower case to line up the screw holes.
    • These screws easily strip, so be careful while taking these particular screws out.
    댓글 쓰기
  7. MacBook Core Duo Optical Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
    댓글 쓰기
  8. MacBook Core Duo Optical Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
    댓글 쓰기
  9. MacBook Core Duo Optical Drive Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the following 4 screws from the back of the computer:
    • Two 7 mm shouldered Phillips on the far sides.
    • Two 10.5 mm Phillips toward the center.
    • Do not over-tighten these; you can cause the case to distort.
    댓글 쓰기
  10. MacBook Core Duo Optical Drive Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
    • It is not necessary to remove the similar screws on the other side of the computer.
    댓글 쓰기
  11. MacBook Core Duo Optical Drive Replacement: 11 단계, 이미지 1개 중 1개
    • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
    • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
    • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
    댓글 쓰기
  12. MacBook Core Duo Optical Drive Replacement: 12 단계, 이미지 1개 중 1개
    • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
    • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
    • Do not pry from the bottom or the top, but from the sides.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
    댓글 쓰기
  13. MacBook Core Duo Optical Drive Replacement, Optical Drive: 13 단계, 이미지 1개 중 1개
    • Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
    댓글 쓰기
  14. MacBook Core Duo Optical Drive Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the two Phillips screws from the front edge of the optical drive.
    • The shorter screw (3 mm) is recessed nearest the RAM modules. The other is 3.5 mm.
    댓글 쓰기
  15. MacBook Core Duo Optical Drive Replacement: 15 단계, 이미지 1개 중 1개
    • Disconnect the orange optical drive ribbon cable from the logic board.
    댓글 쓰기
  16. MacBook Core Duo Optical Drive Replacement: 16 단계, 이미지 1개 중 1개
    • Disconnect the newly-revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
    댓글 쓰기
  17. MacBook Core Duo Optical Drive Replacement: 17 단계, 이미지 1개 중 1개
    • Disconnect the (once again) newly-revealed hard drive cable.
    댓글 쓰기
  18. MacBook Core Duo Optical Drive Replacement: 18 단계, 이미지 1개 중 1개
    • Peel up the foil tape between the fan and the optical drive.
    • Remove the 8.5 mm Phillips screw securing the display data cable to the metal framework.
    댓글 쓰기
  19. MacBook Core Duo Optical Drive Replacement: 19 단계, 이미지 1개 중 1개
    • Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
    댓글 쓰기
  20. MacBook Core Duo Optical Drive Replacement: 20 단계, 이미지 1개 중 1개
    • Remove the 2.8 mm Phillips screw securing the optical drive.
    • The Bluetooth cable may be covering the screw; carefully push it aside before removing the screw.
    • Do not over-tighten this screw when re-mounting. You could break the plastic enclosure.
    • After removing the screw, push the metal tab backwards, towards the fan, to release the front of the optical drive.
    댓글 쓰기
  21. MacBook Core Duo Optical Drive Replacement: 21 단계, 이미지 1개 중 1개
    • Lift the Bluetooth antenna board from the right side of the optical drive.
    댓글 쓰기
    • Deroute the hard drive cable from along the front of the optical drive.
    댓글 쓰기
  22. MacBook Core Duo Optical Drive Replacement: 23 단계, 이미지 1개 중 1개
    • Lift the front edge of the optical drive and slide it up and out of the computer.
    댓글 쓰기
  23. MacBook Core Duo Optical Drive Replacement, Optical Drive Cable: 24 단계, 이미지 1개 중 1개
    • Peel up the orange tape partially covering the orange optical drive cable.
    댓글 쓰기
  24. MacBook Core Duo Optical Drive Replacement: 25 단계, 이미지 1개 중 1개
    • Disconnect the orange cable from the optical drive.
    댓글 쓰기
  25. MacBook Core Duo Optical Drive Replacement, Optical Drive: 26 단계, 이미지 1개 중 1개
    • Use a spudger to carefully pry the silver metal bracket off the left side of the optical drive. Be careful not to bend the bracket, as it is very thin and bends easily. If the bracket doesn't come free easily, heating the adhesive may make prying the bracket off easier.
    댓글 쓰기
  26. MacBook Core Duo Optical Drive Replacement: 27 단계, 이미지 1개 중 1개
    • Peel up the L-shaped piece of black tape from the top of the drive.
    • You'll want to reapply this tape in the same position on your replacement drive.
    댓글 쓰기
  27. MacBook Core Duo Optical Drive Replacement: 28 단계, 이미지 1개 중 1개
    • Peel up the silver foil tape from the optical drive.
    댓글 쓰기
  28. MacBook Core Duo Optical Drive Replacement: 29 단계, 이미지 1개 중 1개
    • Remove the two Phillips screws securing the mounting bracket to the right side of the optical drive.
    • This bracket is designed to slide back and forth slightly, so don't tighten the screws so much that the bracket is unable to slide.
    댓글 쓰기
  29. MacBook Core Duo Optical Drive Replacement: 30 단계, 이미지 1개 중 1개
    • Use a spudger to pry the gray Bluetooth antenna holder off the top of the optical drive.
    • You'll want to reapply this piece in the same position on your replacement drive.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 146명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
4가이드 댓글
Dude, I've done a little work on PCs but not on Macs. This optical drive swap-out was my first time. Super KUDOS to the folks who contributed to this guide (including the helpful notes on practically every page) and the terrific pictures...!!!! I did it in under two hours - without a hitch. THANK YOU...!!!
HappyPappy - 답글 공유
I almost forgot. I got this SuperDrive on eBay - Item:MacBook Pro DVD±RW Superdrive Burner GWA-4080MA - $59.99. That's the one I just installed; from a place called "power_optical". What a deal...!
HappyPappy - 답글 공유
HappyPappy의 인용문:
i have a macbook pro 17“ bought at 2007 and its dvd burner doesn´t work anymore... this you bought does work with mine?
thank you
franK - 답글 공유
this guide is awesome and made the swap of the defective DVD player a breeze..
thanks for posting.
roeiboot - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 22
지난 30일: 95
전체 시간: 223,827
