주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mainboard Assembly
단지 전제 조건
이 가이드는 전제 조건만을 다룹니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. Mainboard Assembly, Unfasten the back cover screws: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the four 11 mm-long screws securing the back cover.
  2. Mainboard Assembly, Insert an opening pick: 2 단계, 이미지 2개 중 1개 Mainboard Assembly, Insert an opening pick: 2 단계, 이미지 2개 중 2개
    • The back cover of the GuliKit Kingkong 2 Pro is held in place by plastic clips.
    • Insert an opening pick into the gap between the front assembly and the back cover at the bottom edge of the controller.
    • Tilt your opening pick downwards to widen the gap.
  3. Mainboard Assembly, Separate the front assembly and back cover: 3 단계, 이미지 2개 중 1개 Mainboard Assembly, Separate the front assembly and back cover: 3 단계, 이미지 2개 중 2개
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the right controller handle.
    • Slide the opening pick along the gap to separate the front assembly from the back cover.
  4. Mainboard Assembly: 4 단계, 이미지 2개 중 1개 Mainboard Assembly: 4 단계, 이미지 2개 중 2개
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the left controller handle.
  5. Mainboard Assembly, Remove the back cover: 5 단계, 이미지 2개 중 1개 Mainboard Assembly, Remove the back cover: 5 단계, 이미지 2개 중 2개
    • Separate the back cover from the front assembly and remove it.
  6. Mainboard Assembly, Disconnect the right vibration motor: 6 단계, 이미지 3개 중 1개 Mainboard Assembly, Disconnect the right vibration motor: 6 단계, 이미지 3개 중 2개 Mainboard Assembly, Disconnect the right vibration motor: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • It's not mandatory to remove the two vibration motors to remove the mainboard assembly. However, other repairs become much easier with the motors removed. If you want to leave the motors in place, you can jump straight to step 9.
    • Pull on the connectors themselves and not the cables to avoid damaging them.
    • Use the point of a spudger to disconnect the right vibration motor by pushing the connector straight out of its socket.
    • If you can't disconnect the vibration motor with a spudger, use a pair of blunt nose tweezers to pull the connector out of its socket.
  7. Mainboard Assembly, Disconnect the left vibration motor: 7 단계, 이미지 3개 중 1개 Mainboard Assembly, Disconnect the left vibration motor: 7 단계, 이미지 3개 중 2개 Mainboard Assembly, Disconnect the left vibration motor: 7 단계, 이미지 3개 중 3개
    • Use the point of a spudger to disconnect the left vibration motor by pushing the connector straight out of its socket.
  8. Mainboard Assembly, Remove the vibration motors: 8 단계, 이미지 1개 중 1개
    • Remove the vibration motors by lifting them out of the controller housing.
  9. Mainboard Assembly, Release the interconnect cable ZIF connector: 9 단계, 이미지 2개 중 1개 Mainboard Assembly, Release the interconnect cable ZIF connector: 9 단계, 이미지 2개 중 2개
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable's ZIF connector.
  10. Mainboard Assembly, Disconnect the interconnect cable: 10 단계, 이미지 2개 중 1개 Mainboard Assembly, Disconnect the interconnect cable: 10 단계, 이미지 2개 중 2개
    • Use a pair of blunt nose tweezers to disconnect the interconnect cable by pulling the cable straight out of the connector.
  11. Mainboard Assembly, Unfasten the mainboard assembly screws: 11 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the screws securing the mainboard assembly:
    • Four 7.8 mm-long screws.
    • Two 11 mm-long screws.
  12. Mainboard Assembly, Remove the mainboard shield: 12 단계, 이미지 2개 중 1개 Mainboard Assembly, Remove the mainboard shield: 12 단계, 이미지 2개 중 2개
    • Use a pair of blunt nose tweezers to remove the metal shield from the mainboard assembly.
  13. Mainboard Assembly, Remove the mainboard assembly: 13 단계, 이미지 3개 중 1개 Mainboard Assembly, Remove the mainboard assembly: 13 단계, 이미지 3개 중 2개 Mainboard Assembly, Remove the mainboard assembly: 13 단계, 이미지 3개 중 3개
    • Remove the mainboard assembly by lifting it out of the controller housing.
결론
작성자
3다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
258,327 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,713개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 35
전체 시간: 441
