주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Meizu MX3 Battery Replacement
필요한 것
  1. Meizu MX3 Battery Replacement, Removing the Back Cover: 1 단계, 이미지 3개 중 1개 Meizu MX3 Battery Replacement, Removing the Back Cover: 1 단계, 이미지 3개 중 2개 Meizu MX3 Battery Replacement, Removing the Back Cover: 1 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool in between the charging port and the back case of the device. Slowly move the tool to the left of the device until you come the top by the power button.
    • Using a paper clip or pointed-edge spudger push in the pin located in the bottom right-hand corner on the back of the phone.
    댓글 쓰기
  2. Meizu MX3 Battery Replacement, Removing the Screws in the Internal Casing: 2 단계, 이미지 3개 중 1개 Meizu MX3 Battery Replacement, Removing the Screws in the Internal Casing: 2 단계, 이미지 3개 중 2개 Meizu MX3 Battery Replacement, Removing the Screws in the Internal Casing: 2 단계, 이미지 3개 중 3개
    • Using one of the small Phillips screwdriver bits provided unscrew the 11 screws present on the protective plastic plate under the device case.
    댓글 쓰기
  3. Meizu MX3 Battery Replacement, Removing the Battery: 3 단계, 이미지 3개 중 1개 Meizu MX3 Battery Replacement, Removing the Battery: 3 단계, 이미지 3개 중 2개 Meizu MX3 Battery Replacement, Removing the Battery: 3 단계, 이미지 3개 중 3개
    • After the 11 screws are loosened use the plastic opening tool and gently pry the protective plate from the back of the device.
    • Once the plate is off, use the same tool to gently remove the 3 ribbon cables located directly above the battery.
    • On the left side of the battery on the phone case, there is a groove where the plastic opening tool can be inserted to pry the battery up and out.
    • The battery might be glued to the phone so exercise caution. Puncturing the battery can cause it to explode and cause a fire.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Mandela Robin
회원 가입일: 09/23/14
876 평판
안내서 6개를 작성함
USF Tampa, Team 15-2, Remmell Fall 2014 USF Tampa, Team 15-2, Remmell Fall 2014 회원
USFT-REMMELL-F14S15G2
4 회원들
안내서 27개를 작성함
1가이드 댓글
The battery cover of my mx3 had 9 screws visibles. The last 2, the top and bottom middle screws, were hidden under a layer of paint and didn't look like screws. Just push the screw driver in and break the paint layer. I would guess that this is the equivalent of a warranty seal, so if your phone is still under warranty think carefully before you do them.
Guillaume - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 38
전체 시간: 6,297
