주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Merch Source Projector Entertainment II Motherboard
필요한 것
    1. Merch Source Projector Entertainment II Motherboard, Outer Casing: 1 단계, 이미지 2개 중 1개 Merch Source Projector Entertainment II Motherboard, Outer Casing: 1 단계, 이미지 2개 중 2개
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      댓글 쓰기
    2. Merch Source Projector Entertainment II Motherboard: 2 단계, 이미지 1개 중 1개
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      댓글 쓰기
    3. Merch Source Projector Entertainment II Motherboard: 3 단계, 이미지 2개 중 1개 Merch Source Projector Entertainment II Motherboard: 3 단계, 이미지 2개 중 2개
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      댓글 쓰기
    1. Merch Source Projector Entertainment II Motherboard, Motherboard: 4 단계, 이미지 2개 중 1개 Merch Source Projector Entertainment II Motherboard, Motherboard: 4 단계, 이미지 2개 중 2개
      • Use the plastic opening tool to gently disengage the ribbon cable from its back housing.
      • Once the ribbon cable is disengaged gently pull the cable off the motherboard.
      • Once the housing is disengaged, the ribbon cable should slide out easy. Do not pull too hard on the ribbon cable as it is very fragile.
      댓글 쓰기
    2. Merch Source Projector Entertainment II Motherboard: 5 단계, 이미지 2개 중 1개 Merch Source Projector Entertainment II Motherboard: 5 단계, 이미지 2개 중 2개
      • Unscrew the three 6 mm screws from the motherboard with the Phillips #0 screwdriver.
      • Be sure not to damage any of the wires atached to the motherboard.
      댓글 쓰기
    3. Merch Source Projector Entertainment II Motherboard: 6 단계, 이미지 2개 중 1개 Merch Source Projector Entertainment II Motherboard: 6 단계, 이미지 2개 중 2개
      • Solder off all of the connections on the motherboard with a soldering iron.
      • Once connections are soldered off, the motherboard should be detached and ready for replacement.
      • Need some help? Follow this guide to learn soldering basics.
      • While soldering the metal connections can get very hot. Never touch the iron with your hand. also make sure that the projector is fully turned off and not plugged in.
      • If there is hot glue on top on the connection with the motherboard, you will need to peel it off using your fingers.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Michael Tan
회원 가입일: 01/08/15
590 평판
안내서 3개를 작성함
3가이드 댓글
Was wondering if you could help me identify a microchip on the board by the speaker?
Brad Langland - 답글 공유
Where can I get parts for the projector? I think my board is cooked.
Delgtm - 답글 공유
mine acts like it does not recognize the rca cords. help
Kamela Mitchell - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 37
전체 시간: 2,408
