주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Meta Quest 2 Controller Ring Shell Replacement
필요한 것
  1. Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 3개
    • Use your fingers to slide the battery cover down towards the strap end of the controller.
    • Remove the battery cover.
    • If you're taking the controller apart for repairs, remove the batteries in the controller.
    댓글 쓰기
  2. Meta Quest 2 Controller Ring Shell Replacement, Remove the wrist strap: 2 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Ring Shell Replacement, Remove the wrist strap: 2 단계, 이미지 2개 중 2개
    • Use your fingers to grasp the wrist strap near the anchor peg.
    • Lift the wrist strap anchor peg straight out of its recess.
    • Remove the wrist strap.
    댓글 쓰기
  3. Meta Quest 2 Controller Ring Shell Replacement, Loosen the faceplate adhesive: 3 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
    댓글 쓰기
  4. Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: 4 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: 4 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: 4 단계, 이미지 3개 중 3개
    • The controller faceplate is secured with adhesive and three friction pegs.
    • Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
    • If you can’t get the opening tool into the seam, heat the area with an iOpener for a minute and try again.
    • Slide the opening tool to the base of the ring shell to loosen the adhesive.
    댓글 쓰기
  5. Meta Quest 2 Controller Ring Shell Replacement: 5 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Ring Shell Replacement: 5 단계, 이미지 2개 중 2개
    • Use an opening tool to pry up on the seam to loosen the first friction peg.
    댓글 쓰기
  6. Meta Quest 2 Controller Ring Shell Replacement: 6 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Ring Shell Replacement: 6 단계, 이미지 2개 중 2개
    • Continue prying around the entire faceplate to separate the remaining friction pegs and adhesive.
    • If you're having trouble, apply a heated iOpener to the faceplate for a minute and try again.
    댓글 쓰기
  7. Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: 7 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: 7 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: 7 단계, 이미지 3개 중 3개
    • Remove the controller faceplate.
    • The three friction pegs should hold the faceplate securely, so you don’t need to replace the adhesive during reassembly. Be sure to firmly press the faceplate onto the controller so that all friction pegs fully engage.
    댓글 쓰기
  8. Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller ring shell: 8 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller ring shell: 8 단계, 이미지 2개 중 2개
    • Use a Torx T5 driver to remove the four screws securing the controller ring shell to the controller:
    • Two 4.7 mm‑long screws
    • Two 5.9 mm‑long screws
    댓글 쓰기
  9. Meta Quest 2 Controller Ring Shell Replacement: 9 단계, 이미지 2개 중 1개 Meta Quest 2 Controller Ring Shell Replacement: 9 단계, 이미지 2개 중 2개
    • Press the point of a spudger firmly against the white alignment square to release the ring shell.
    댓글 쓰기
  10. Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: 10 단계, 이미지 3개 중 1개 Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: 10 단계, 이미지 3개 중 2개 Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: 10 단계, 이미지 3개 중 3개
    • Use your fingers to grab the end of the ring shell that doesn’t have the white alignment square.
    • Gently lift the ring shell up and away from the controller to unclip it from the controller.
    • Remove the controller ring shell.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
344,106 평판
안내서 915개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 31,535개를 작성함
1가이드 댓글
This Tutorial was really fast and easy also, I fixed my controller and it works very well now, Thank you!
# “‪Diamond‬” # - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 40
지난 30일: 197
전체 시간: 7,598
