주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Metal Snap Installation Using a Hand Press
필요한 것
  1. Metal Snap Installation Using a Hand Press, Metal snap types: 1 단계, 이미지 2개 중 1개 Metal Snap Installation Using a Hand Press, Metal snap types: 1 단계, 이미지 2개 중 2개
    • There are two main styles of metal snaps on Patagonia gear:
    • Flat Spring Snap - This style is commonly found on clothing because it snaps and unsnaps smoothly.
    • Durable Socket Snap - This style is commonly found on packs and luggage because it has thicker metal that can withstand heavy use.
    • Each piece of the snap has its own corresponding snap die. Make sure you use the correct size and style of snap.
    댓글 쓰기
  2. Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap base: 2 단계, 이미지 2개 중 1개 Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap base: 2 단계, 이미지 2개 중 2개
    • This tutorial will demonstrate with the Durable Socket Snap, but the same actions can be applied to the Flat Spring Snap.
    • Gather the stud and post pieces and their corresponding dies.
    • The stud and post are compressed together with the press to create the base of the snap.
    댓글 쓰기
  3. Metal Snap Installation Using a Hand Press, Insert the post into the post die: 3 단계, 이미지 3개 중 1개 Metal Snap Installation Using a Hand Press, Insert the post into the post die: 3 단계, 이미지 3개 중 2개 Metal Snap Installation Using a Hand Press, Insert the post into the post die: 3 단계, 이미지 3개 중 3개
    • Insert the post piece into the post die so the flat part of the post sits inside the die with the shaft pointed out.
    댓글 쓰기
  4. Metal Snap Installation Using a Hand Press, Insert the post die into the hand press: 4 단계, 이미지 2개 중 1개 Metal Snap Installation Using a Hand Press, Insert the post die into the hand press: 4 단계, 이미지 2개 중 2개
    • Insert the post die into the lower fitting of the hand press.
    댓글 쓰기
  5. Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: 5 단계, 이미지 3개 중 1개 Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: 5 단계, 이미지 3개 중 2개 Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: 5 단계, 이미지 3개 중 3개
    • Insert the stud piece into the stud die until it snaps into place.
    댓글 쓰기
  6. Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: 6 단계, 이미지 3개 중 1개 Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: 6 단계, 이미지 3개 중 2개 Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: 6 단계, 이미지 3개 중 3개
    • Using your fingers, a screwdriver, or a hex key, as needed, unscrew the tightening mechanism on the side of the press near the die fitting.
    • Insert the die upward and hold it in place.
    • Tighten the tightening mechanism.
    댓글 쓰기
  7. Metal Snap Installation Using a Hand Press, Install the snap base: 7 단계, 이미지 3개 중 1개 Metal Snap Installation Using a Hand Press, Install the snap base: 7 단계, 이미지 3개 중 2개 Metal Snap Installation Using a Hand Press, Install the snap base: 7 단계, 이미지 3개 중 3개
    • Lay the item to be repaired into the hand press so that the hole from the original snap rests directly above the shaft of the post.
    • If the fabric around the old snap is torn or damaged beyond a small hole, apply a patch to reinforce the area before replacing the snap.
    • Make sure no extra fabric is caught inside the press and that the orientation of the item is correct.
    • Hold the fabric in place with one hand, then use your other hand to pull down the handle of the press.
    • This requires a lot of pressure to make sure the snap replacement is successful - so pull hard!
    댓글 쓰기
  8. Metal Snap Installation Using a Hand Press, Quality control: 8 단계, 이미지 2개 중 1개 Metal Snap Installation Using a Hand Press, Quality control: 8 단계, 이미지 2개 중 2개
    • Release the handle of the hand press and remove the fabric.
    • Inspect both sides of the snap to make sure:
    • It is not cracked, crushed, or misshapen.
    • It's laying flat and flush up against the fabric.
    • It doesn't spin in place.
    • It fastens together securely with the head of the snap.
    • If the snap isn't set all the way, reinsert the snap into the hand press, aligning it as it was before, and pull the handle again.
    댓글 쓰기
  9. Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap head: 9 단계, 이미지 2개 중 1개 Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap head: 9 단계, 이미지 2개 중 2개
    • Gather the socket and cap pieces and their corresponding dies.
    • The socket and cap are compressed together with the press to create the head of the snap.
    댓글 쓰기
  10. Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: 10 단계, 이미지 3개 중 1개 Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: 10 단계, 이미지 3개 중 2개 Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: 10 단계, 이미지 3개 중 3개
    • Insert the cap piece into the cap die so it sits inside the die with the shaft facing out.
    댓글 쓰기
  11. Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: 11 단계, 이미지 3개 중 1개 Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: 11 단계, 이미지 3개 중 2개 Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: 11 단계, 이미지 3개 중 3개
    • Insert the cap die into the lower fitting of the hand press.
    댓글 쓰기
  12. Metal Snap Installation Using a Hand Press, Insert the socket into the socket die: 12 단계, 이미지 2개 중 1개 Metal Snap Installation Using a Hand Press, Insert the socket into the socket die: 12 단계, 이미지 2개 중 2개
    • Insert the socket piece into the socket die until it snaps into place.
    댓글 쓰기
  13. Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: 13 단계, 이미지 3개 중 1개 Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: 13 단계, 이미지 3개 중 2개 Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: 13 단계, 이미지 3개 중 3개
    댓글 쓰기
  14. Metal Snap Installation Using a Hand Press, Install the snap head: 14 단계, 이미지 3개 중 1개 Metal Snap Installation Using a Hand Press, Install the snap head: 14 단계, 이미지 3개 중 2개 Metal Snap Installation Using a Hand Press, Install the snap head: 14 단계, 이미지 3개 중 3개
    댓글 쓰기
  15. Metal Snap Installation Using a Hand Press, Quality control: 15 단계, 이미지 2개 중 1개 Metal Snap Installation Using a Hand Press, Quality control: 15 단계, 이미지 2개 중 2개
    • It fastens together securely with the base of the snap.
    댓글 쓰기
  16. Metal Snap Installation Using a Hand Press, Examples: 16 단계, 이미지 2개 중 1개 Metal Snap Installation Using a Hand Press, Examples: 16 단계, 이미지 2개 중 2개
    • The rain jacket in the first photo has flat spring metal snaps along the center front zipper placket.
    • The duffel bag in the second photo has durable socket metal snaps at the handle grip.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
90,914 평판
안내서 142개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 21
지난 7일: 70
지난 30일: 262
전체 시간: 25,033
