주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Micro-USB Port Replacement
필요한 것
    1. Micro-USB Port Replacement, Back Plate: 1 단계, 이미지 2개 중 1개 Micro-USB Port Replacement, Back Plate: 1 단계, 이미지 2개 중 2개
      • Unscrew the four 3.4 mm flat head screws
      댓글 쓰기
    2. Micro-USB Port Replacement: 2 단계, 이미지 1개 중 1개
      • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
      댓글 쓰기
    1. Micro-USB Port Replacement, Lithium Battery: 3 단계, 이미지 1개 중 1개
      • If not replacing lithium battery, skip down two steps.
      • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
      댓글 쓰기
    2. Micro-USB Port Replacement: 4 단계, 이미지 1개 중 1개
      • Desolder the battery connections from the motherboard. Learn how to solder components here!
      댓글 쓰기
    1. Micro-USB Port Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
      • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
      댓글 쓰기
    2. Micro-USB Port Replacement: 6 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
      댓글 쓰기
    3. Micro-USB Port Replacement: 7 단계, 이미지 1개 중 1개
      • Use PH00 screwdriver to remove 5.2mm Phillips head screw
      댓글 쓰기
    4. Micro-USB Port Replacement: 8 단계, 이미지 3개 중 1개 Micro-USB Port Replacement: 8 단계, 이미지 3개 중 2개 Micro-USB Port Replacement: 8 단계, 이미지 3개 중 3개
      • Use ESD safe tweezers to remove the gold ribbon cable.
      • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
      댓글 쓰기
    5. Micro-USB Port Replacement: 9 단계, 이미지 2개 중 1개 Micro-USB Port Replacement: 9 단계, 이미지 2개 중 2개
      • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
      • You can now access the parts and pieces on the bottom of, and below the motherboard.
      댓글 쓰기
    1. Micro-USB Port Replacement, Micro-USB Port: 10 단계, 이미지 1개 중 1개
      • Locate the four main soldering points marked in red.
      • Be aware of the five additional soldered pins marked by the blue arrow.
      댓글 쓰기
    2. Micro-USB Port Replacement: 11 단계, 이미지 3개 중 1개 Micro-USB Port Replacement: 11 단계, 이미지 3개 중 2개 Micro-USB Port Replacement: 11 단계, 이미지 3개 중 3개
      • Begin to desolder the points pointed out in the last step.
      • Use the soldering wick to help remove the solder.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Michael Miller
회원 가입일: 10/24/16
281 평판
안내서 2개를 작성함
IUPUI, Team 3-3, Baechle Fall 2016 IUPUI, Team 3-3, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S3G3
4 회원들
안내서 16개를 작성함
1가이드 댓글
I want to know that what I have to do if want to replace the lithium battery with usb direct powered device.
amupis232389 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 24
지난 30일: 87
전체 시간: 18,399
