주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft Surface 3 Kickstand Replacement
필요한 것
    1. Microsoft Surface 3 Kickstand Replacement, Casing: 1 단계, 이미지 2개 중 1개 Microsoft Surface 3 Kickstand Replacement, Casing: 1 단계, 이미지 2개 중 2개
      • Warm up an iOpener following the instructions found in the iOpener guide.
      • Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
      댓글 쓰기
    2. Microsoft Surface 3 Kickstand Replacement: 2 단계, 이미지 2개 중 1개 Microsoft Surface 3 Kickstand Replacement: 2 단계, 이미지 2개 중 2개
      • Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
      • This may take significant force. A fingernail might work better for the initial lift
      • If you push straight down near the edge you will go through the speaker mesh and possibly end up damaging your speaker; try to push the pick in at a shallow angle.
      댓글 쓰기
    3. Microsoft Surface 3 Kickstand Replacement: 3 단계, 이미지 2개 중 1개 Microsoft Surface 3 Kickstand Replacement: 3 단계, 이미지 2개 중 2개
      • Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
      • If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
      • While the glass on this display is not particularly sharp when broken, it is still broken glass and you should be careful with it.
      댓글 쓰기
    4. Microsoft Surface 3 Kickstand Replacement: 4 단계, 이미지 1개 중 1개
      • Flip the display over so that parts underneath it are easily accessible.
      • Do not pull out the display as it is still attached to the motherboard.
      • If you are replacing the display, or want it out of the way, continue with the display replacement guide steps.
      댓글 쓰기
    1. Microsoft Surface 3 Kickstand Replacement, Battery: 5 단계, 이미지 1개 중 1개
      • Now that you've gotten the casing off of the Surface 3, you can start removing the battery pack.
      댓글 쓰기
    2. Microsoft Surface 3 Kickstand Replacement: 6 단계, 이미지 3개 중 1개 Microsoft Surface 3 Kickstand Replacement: 6 단계, 이미지 3개 중 2개 Microsoft Surface 3 Kickstand Replacement: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • Slide the iFixit plastic cards under the compartments of the battery pack.
      • Slide the card around to undo the adhesive under the battery pack
      댓글 쓰기
    3. Microsoft Surface 3 Kickstand Replacement: 7 단계, 이미지 3개 중 1개 Microsoft Surface 3 Kickstand Replacement: 7 단계, 이미지 3개 중 2개 Microsoft Surface 3 Kickstand Replacement: 7 단계, 이미지 3개 중 3개
      • Carefully slide the battery's flat power and data connector from its insert.
      • You may now switch out the battery pack for a new one.
      댓글 쓰기
    1. Microsoft Surface 3 Kickstand Replacement, Kickstand: 8 단계, 이미지 2개 중 1개 Microsoft Surface 3 Kickstand Replacement, Kickstand: 8 단계, 이미지 2개 중 2개
      • Remove these four 3/32" Torx #3 screws.
      • If you do not need to remove the hinges, skip to the step that handles the retaining tabs.
      댓글 쓰기
    2. Microsoft Surface 3 Kickstand Replacement: 9 단계, 이미지 2개 중 1개 Microsoft Surface 3 Kickstand Replacement: 9 단계, 이미지 2개 중 2개
      • Remove these four 3/16" Torx #5 screws that hold in the hinges to replace the hinges.
      댓글 쓰기
    3. Microsoft Surface 3 Kickstand Replacement: 10 단계, 이미지 3개 중 1개 Microsoft Surface 3 Kickstand Replacement: 10 단계, 이미지 3개 중 2개 Microsoft Surface 3 Kickstand Replacement: 10 단계, 이미지 3개 중 3개
      • These two retaining tabs need to be fed through the slots in the case to release the kickstand.
      • Use picks to make the tab slide through the slot then simply pull out the kickstand,
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Harold Hall
회원 가입일: 10/08/15
1,332 평판
안내서 3개를 작성함
Cal Poly, Team 5-12, Maness Fall 2015 Cal Poly, Team 5-12, Maness Fall 2015 회원
CPSU-MANESS-F15S5G12
4 회원들
안내서 22개를 작성함
2가이드 댓글
I think I will NOT be trying to do this. To many potentials for something to go wrong beyond your control, even when being extra careful. I do not feel like replacing someone’s device if that happens.
QuickTech - 답글 공유
Please can you tell me which kickstand the surface pro 3 64 GB (2013) needs? Is it the same as the surface pro 4 ? I have broken the stand and am trying yo source a replacement.
Tilly Mortimore - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 39
전체 시간: 10,095
