주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft Surface Book 2 15" Battery Replacement
필요한 것
  1. Microsoft Surface Book 2 15" Battery Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Open the laptop, then orient it so the touchpad is on your left.
    • Starting at the hinge, count six holes up on the tablet portion of the laptop.
    댓글 쓰기
  2. Microsoft Surface Book 2 15" Battery Replacement: 2 단계, 이미지 2개 중 1개 Microsoft Surface Book 2 15" Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Take a paper clip and unfold it.
    • Place the paper clip in the sixth hole and push until you hear a click.
    • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
    • After the right side has been detached, lift up the left side as well.
    댓글 쓰기
  3. Microsoft Surface Book 2 15" Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Place the tablet on a flat surface.
    • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
    댓글 쓰기
  4. Microsoft Surface Book 2 15" Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Using a plastic pick, slice underneath the edge of the screen.
    • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
    • Take care not to insert the tool too far to avoid cutting the ribbon cables.
    • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
    • Don't use a metal tool, that could damage the screen or internal parts.
    댓글 쓰기
  5. Microsoft Surface Book 2 15" Battery Replacement: 5 단계, 이미지 2개 중 1개 Microsoft Surface Book 2 15" Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Lift up the screen.
    • Detach the ribbon cables connecting the underside of the screen to the motherboard.
    댓글 쓰기
  6. Microsoft Surface Book 2 15" Battery Replacement: 6 단계, 이미지 2개 중 1개 Microsoft Surface Book 2 15" Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
    • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
    댓글 쓰기
  7. Microsoft Surface Book 2 15" Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Once the screws are removed from the top bar, gently lift up and remove it.
    • Be careful not to damage any ribbon cables or wires.
    • Gently lift up on the motherboard to remove it.
    댓글 쓰기
  8. Microsoft Surface Book 2 15" Battery Replacement, Battery Removal: 8 단계, 이미지 2개 중 1개 Microsoft Surface Book 2 15" Battery Replacement, Battery Removal: 8 단계, 이미지 2개 중 2개
    • Use an iOpener or a heat gun (on low heat) to carefully heat the back side of the tablet to help soften the battery adhesive.
    • Use prying tools such as a guitar pick, plastic card, or a nylon spudger to help sever the adhesive and gently lift the battery free.
    • After the case cools, a careful amount of isopropyl alcohol can help dissolve stubborn glue between the battery and the case.
    • Work slowly and carefully. Do not pry, bend, or puncture the battery while removing it from the tablet.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Ryan Picewick
회원 가입일: 03/13/23
537 평판
안내서 4개를 작성함
UMass Dartmouth, Team 3-3, Petersen Spring 2023 UMass Dartmouth, Team 3-3, Petersen Spring 2023 회원
UMASSD-PETERSEN-S23S3G3
4 회원들
안내서 23개를 작성함
5가이드 댓글
The first paragraph of this Surface Book 2 battery replacement guide is:
"This guide explains how to replace the battery in the Microsoft Surface Book 2 15". It requires the motherboard replacement guide as a prerequisite guide, which is a very difficult guide to follow without breaking the laptop."
The first paragraph of the motherboard replacement guide is:
This guide is used to explain how to open up the tablet portion of the Microsoft Surface Book 2 15 and gain access to the motherboard. The motherboard of the Microsoft Surface Book 2 15 has a majority of the cables for parts that can be replaced on it.
Does this mean that I have to go through all the replacement motherboard steps and replace the motherboard before replacing the battery?
Nicholas Law - 답글 공유
You won't need to replace the mobo, but yes, it looks like you'll have to remove it. This guide is pretty confusing right now IMO
darth mango - 답글 공유
I also find it rather confusing.
Thanks darth mango.
Is it true that the battery in the Surface Book 2 has frequently failed completely?
No charging possible, always 0%.
When a battery ages, you can still charge it to 100%.
Very fast (bad), but “full”.
A total failure would rather be the battery management system.
I wonder if there were also failures of the charging current to the battery, i.e. a defect on the circuit board of the tablet screen.
That would be annoying, of course, because you can't just fix the fault by replacing the battery.
But replacing the entire battery would also be annoying if only the BMS is defective.
All you need is a replacement with comparable values and size, which you solder into the center of the battery.
And what about the assembly?
Are there adhesive strips in this form?
Or should you just use BT-7000 liquid glue?
I bought this for a Samsung Galaxy Note-9 to seal it watertight again after replacing the USB port.
Tobias Claren - 답글 공유
Meine Akkus sind plötzlich auf 0% hängen geblieben. Aufladen nicht mehr möglich. Nur noch Netzbetrieb meines Surface 2. Schade. Akkutausch zu teuer.
Stefan Schwarz - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 19
지난 7일: 226
지난 30일: 875
전체 시간: 35,328
