주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft Surface Book 2 15" Front Camera Replacement
필요한 것
  1. Microsoft Surface Book 2 15" Front Camera Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Open the laptop, then orient it so the touchpad is on your left.
    • Starting at the hinge, count six holes up on the tablet portion of the laptop.
    댓글 쓰기
  2. Microsoft Surface Book 2 15" Front Camera Replacement: 2 단계, 이미지 2개 중 1개 Microsoft Surface Book 2 15" Front Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Take a paper clip and unfold it.
    • Place the paper clip in the sixth hole and push until you hear a click.
    • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
    • After the right side has been detached, lift up the left side as well.
    댓글 쓰기
  3. Microsoft Surface Book 2 15" Front Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Place the tablet on a flat surface.
    • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
    댓글 쓰기
  4. Microsoft Surface Book 2 15" Front Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Using a plastic pick, slice underneath the edge of the screen.
    • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
    • Take care not to insert the tool too far to avoid cutting the ribbon cables.
    • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
    • Don't use a metal tool, that could damage the screen or internal parts.
    댓글 쓰기
  5. Microsoft Surface Book 2 15" Front Camera Replacement: 5 단계, 이미지 2개 중 1개 Microsoft Surface Book 2 15" Front Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Lift up the screen.
    • Detach the ribbon cables connecting the underside of the screen to the motherboard.
    댓글 쓰기
  6. Microsoft Surface Book 2 15" Front Camera Replacement: 6 단계, 이미지 2개 중 1개 Microsoft Surface Book 2 15" Front Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
    • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
    댓글 쓰기
  7. Microsoft Surface Book 2 15" Front Camera Replacement: 7 단계, 이미지 1개 중 1개
    • Once the screws are removed from the top bar, gently lift up and remove it.
    • Be careful not to damage any ribbon cables or wires.
    • Gently lift up on the motherboard to remove it.
    댓글 쓰기
  8. Microsoft Surface Book 2 15" Front Camera Replacement, Front Camera: 8 단계, 이미지 1개 중 1개
    • After lifting the motherboard, locate the two cameras near the center of the motherboard.
    • Unplug front camera (right side) from the motherboard (lift carefully).
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Colton Almeida
회원 가입일: 03/13/23
172 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-3, Petersen Spring 2023 UMass Dartmouth, Team 3-3, Petersen Spring 2023 회원
UMASSD-PETERSEN-S23S3G3
4 회원들
안내서 23개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 39
전체 시간: 826
