주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft Surface Book Screen Replacement
필요한 것
  1. Microsoft Surface Book Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Heat an iOpener and lay it on the bottom edge of the screen to soften the glue securing it.
    • You can also use a hair dryer or heat gun, but be careful as extreme heat can damage the screen and/or battery.
    댓글 쓰기
  2. Microsoft Surface Book Screen Replacement, Anti-Clamp instructions: 2 단계, 이미지 3개 중 1개 Microsoft Surface Book Screen Replacement, Anti-Clamp instructions: 2 단계, 이미지 3개 중 2개 Microsoft Surface Book Screen Replacement, Anti-Clamp instructions: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your Surface Book so it rests level between the suction cups.
    • Position the suction cups near the middle of the bottom edge—one on the front, and one on the back.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
    댓글 쓰기
  3. Microsoft Surface Book Screen Replacement: 3 단계, 이미지 3개 중 1개 Microsoft Surface Book Screen Replacement: 3 단계, 이미지 3개 중 2개 Microsoft Surface Book Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    댓글 쓰기
  4. Microsoft Surface Book Screen Replacement: 4 단계, 이미지 3개 중 1개 Microsoft Surface Book Screen Replacement: 4 단계, 이미지 3개 중 2개 Microsoft Surface Book Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the bottom edge.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
    댓글 쓰기
  5. Microsoft Surface Book Screen Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 1개 Microsoft Surface Book Screen Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 2개 Microsoft Surface Book Screen Replacement, Insert an opening pick: 5 단계, 이미지 3개 중 3개
    • The adhesive securing the screen is very strong. This step may take significant force and multiple attempts.
    • Apply a suction handle to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
    댓글 쓰기
  6. Microsoft Surface Book Screen Replacement: 6 단계, 이미지 2개 중 1개 Microsoft Surface Book Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Use the pick to slice all the way around the perimeter of the screen to separate the glue.
    • Do not insert the opening pick too far into the screen or you may cause damage to internal components.
    • Gently raise the screen but don't fully detach it until the cables underneath are disconnected.
    댓글 쓰기
  7. Microsoft Surface Book Screen Replacement: 7 단계, 이미지 3개 중 1개 Microsoft Surface Book Screen Replacement: 7 단계, 이미지 3개 중 2개 Microsoft Surface Book Screen Replacement: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Begin by removing the ribbon on the right. With the curved tweezers, carefully remove the metal bracket to expose the end of the ribbon. Remove ribbon.
    댓글 쓰기
  8. Microsoft Surface Book Screen Replacement: 8 단계, 이미지 3개 중 1개 Microsoft Surface Book Screen Replacement: 8 단계, 이미지 3개 중 2개 Microsoft Surface Book Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Next, remove the metal shield covering the other ribbon. Then remove the ribbon.
    • Remove the screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 27명이 해당 안내서를 완성하였습니다.
작성자
14다른 기여자 명과 함께
Wesley Kendrick
회원 가입일: 02/15/17
2,327 평판
안내서 2개를 작성함
USF Tampa, Team 1-6, Sullivan Spring 2017 USF Tampa, Team 1-6, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S1G6
3 회원들
안내서 14개를 작성함
34가이드 댓글
It is very unlikely you will get this screen off without breaking it. Luckily, my customer only wanted the SSD out of the device so he didn't care if I damaged it. This screen is crazy fragile and the glue is very very strong. Do not do this job thinking you will likely not break the screen, unless you have done it before.
Kevin Yaniak - 답글 공유
The only way to remove it without breaking it is to use good scotch tape and completely cover the screen with a minimum 4 layers of tape. This will keep the screen intact - but you still have to be very careful.
Michael Griffiths - 답글 공유
That’s definitely not the only way. I just did it with a guitar pick and heat pad. After doing a ton of Surface Pro 3’s, I think this one is actually pretty easy in comparison.
austin - 답글 공유
I needed 3 hours for this, Did this the first time. There is everything glued. and real hard to not break the screen.
Dennis Reimer - 답글 공유
Can you put the screen back on after removing it?
Alex Shinnerl - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 36
지난 30일: 249
전체 시간: 61,496
