소개
Use the guide to replace both or one of your broken or wasted thumbsticks in your Xbox Series X controller.
The thumbsticks are the central part of the controller that allows for most of your in-game movement. A wasted or broken thumbstick could reduce your performance for some of your favorite games.
Before using this guide, make sure to ensure that your thumbsticks are the ones wasted or broken because if it is stick drift, then this is not the correct guide for you to follow.
필요한 것
Remove the battery pack cover.
If there are any batteries inside of it, remove them.
Place an iFixit opening tool between the seam of both the front and side plates.
Move the tool repeatedly along the seam between the two plates until the side plate is wholly disconnected from the front plate.
I find it easier to go from the back by the side of the battery compartment. That seems to work better with the positioning of the clips for removing the cover.
I agree with MaFt; the side approach seems to give a lot more resistance than the back approach. I also recommend going at it from the side of the battery compartment.
다른 16명이 해당 안내서를 완성하였습니다.
댓글 4개
@aaron73239 , to fix the joystick drift, you might want to try this guide.
Perhaps it is this article? Xbox One Wireless Controller Model 1708 Button Replacement
Would be appreciated if someone with relevant knowledge or experience would confirm this.
Pictory -
