주요 콘텐츠로 건너뛰기
Microsoft Zune 30 GB Back Case Replacement
jmorri04
jmorri0420 다른 기여자
최종 수정일 May 23, 2016
5 - 10 분
쉬움
Remove the back case of the Zune 30 GB.
필요한 것
도구
더보기...
  1. Microsoft Zune 30 GB Back Case Replacement, Back Case: 1 단계, 이미지 2개 중 1개 Microsoft Zune 30 GB Back Case Replacement, Back Case: 1 단계, 이미지 2개 중 2개
    • Remove the plastic screw cover located on the bottom of the device. Insert a small flat-headed screwdriver into one side of the cover and gently ease it out. Repeat on the other side.
    • Be gentle when removing the screw cover as it is brittle and will break if forced.
    • You will need a #00 Phillips screwdriver to remove the two 2.6 mm screws that are exposed.
  2. Microsoft Zune 30 GB Back Case Replacement: 2 단계, 이미지 1개 중 1개
    • Use the blue plastic opening tool to slowly work your way around the edges of the case, releasing the front plate from the bottom case.
    • Be gentle when prying the device open.
  3. Microsoft Zune 30 GB Back Case Replacement: 3 단계, 이미지 2개 중 1개 Microsoft Zune 30 GB Back Case Replacement: 3 단계, 이미지 2개 중 2개
    • Turn the Zune over so the screen faces downward. This will ensure the battery does not fall out and pull on the cable.
    • The battery is not fastened to the inside of the case. It will fall out.
    • Pry up from the bottom of the Zune because the headphone jack will not allow you to remove the back case in one pull. You must slide the case up and away from the rest of the Zune.
    • The case is now separated. You can replace the case, if needed.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
20다른 기여자 명과 함께
jmorri04
회원 가입일: 10/16/09
308 평판
안내서 2개를 작성함
Cal Poly, Team 19-4, Maness Fall 2009 Cal Poly, Team 19-4, Maness Fall 2009 회원
CPSU-MANESS-F09S19G4
3 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 49
전체 시간: 7,420
