주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Droid RAZR M Battery Replacement
필요한 것
  1. Motorola Droid RAZR M Battery Replacement, Front Assembly: 1 단계, 이미지 3개 중 1개 Motorola Droid RAZR M Battery Replacement, Front Assembly: 1 단계, 이미지 3개 중 2개 Motorola Droid RAZR M Battery Replacement, Front Assembly: 1 단계, 이미지 3개 중 3개
    • Open the small latch on the left side of the device by lifting gently with your finger, exposing the SIM card and microSD card slots.
    • If either of these cards are present, remove them to prevent damaging them while taking apart the phone. Our device does not have either.
    • Close the latch once the two cards are removed.
    댓글 쓰기
  2. Motorola Droid RAZR M Battery Replacement: 2 단계, 이미지 3개 중 1개 Motorola Droid RAZR M Battery Replacement: 2 단계, 이미지 3개 중 2개 Motorola Droid RAZR M Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the six 4mm T3 Torx screws. There are 3 on each side of the device.
    댓글 쓰기
  3. Motorola Droid RAZR M Battery Replacement: 3 단계, 이미지 3개 중 1개 Motorola Droid RAZR M Battery Replacement: 3 단계, 이미지 3개 중 2개 Motorola Droid RAZR M Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Run the plastic opening tool under the bottom edge of the phone to detach the small plastic cover below the Verizon logo.
    • It will take some force to remove this piece. Work around the bottom corners to unlatch the two hooks holding the piece in place.
    • The small plastic hooks can break during removal. Be careful that you don't damage them, but it will take some force to get them undone.
    • Once the plastic cover is detached, pull the piece away with your fingers.
    댓글 쓰기
  4. Motorola Droid RAZR M Battery Replacement: 4 단계, 이미지 2개 중 1개 Motorola Droid RAZR M Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the three T4 Torx screws. There are three at the bottom of the device.
    댓글 쓰기
  5. Motorola Droid RAZR M Battery Replacement: 5 단계, 이미지 3개 중 1개 Motorola Droid RAZR M Battery Replacement: 5 단계, 이미지 3개 중 2개 Motorola Droid RAZR M Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Using the plastic opening tool, peel away the silver Motorola plate at the top of the phone. There is a fair amount of adhesive underneath, so you may have to pry it from a few different angles.
    • As soon as you can get your finger underneath, pull away the silver plate.
    댓글 쓰기
  6. Motorola Droid RAZR M Battery Replacement: 6 단계, 이미지 2개 중 1개 Motorola Droid RAZR M Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the two 7mm T4 Torx screws at the top of the device.
    댓글 쓰기
  7. Motorola Droid RAZR M Battery Replacement: 7 단계, 이미지 3개 중 1개 Motorola Droid RAZR M Battery Replacement: 7 단계, 이미지 3개 중 2개 Motorola Droid RAZR M Battery Replacement: 7 단계, 이미지 3개 중 3개
    • When you detach the front from the back, don't pull the two pieces entirely apart. There is a flat orange wire that connects the two pieces that will be disconnected in the next step.
    • Snap apart the two internal clips located on the top corners of the device, and the two clips in the bottom corners.
    • Run the plastic opening tool around the edge of the entire device to pry apart the front of the phone from the back.
    • There is a small black plastic piece located at the bottom of the front assembly. Do not worry if the strip falls off; just simply snap it back on and proceed.
    댓글 쓰기
  8. Motorola Droid RAZR M Battery Replacement: 8 단계, 이미지 3개 중 1개 Motorola Droid RAZR M Battery Replacement: 8 단계, 이미지 3개 중 2개 Motorola Droid RAZR M Battery Replacement: 8 단계, 이미지 3개 중 3개
    • Like a clamshell, slowly open the device from the top. Open the remainder of the device slowly while being mindful of the flat orange wire that connects the motherboard to the front assembly.
    • Undo the snap connection in the lower left corner by inserting the plastic opening tool under the end of the orange wire connected to the motherboard. Lift gently.
    • Once the snap connection is undone, pull apart the front assembly from the rest of the phone.
    댓글 쓰기
  9. Motorola Droid RAZR M Battery Replacement, Motherboard: 9 단계, 이미지 2개 중 1개 Motorola Droid RAZR M Battery Replacement, Motherboard: 9 단계, 이미지 2개 중 2개
    • Remove the six 4mm T5 Torx screws located along the outer edge of the motherboard.
    댓글 쓰기
  10. Motorola Droid RAZR M Battery Replacement: 10 단계, 이미지 2개 중 1개 Motorola Droid RAZR M Battery Replacement: 10 단계, 이미지 2개 중 2개
    • Disconnect the snap connection in the lower left corner by prying underneath using the plastic opening tool.
    댓글 쓰기
  11. Motorola Droid RAZR M Battery Replacement: 11 단계, 이미지 2개 중 1개 Motorola Droid RAZR M Battery Replacement: 11 단계, 이미지 2개 중 2개
    • Disconnect the snap connection in the upper left corner by prying underneath using the plastic opening tool.
    • As you undo the snap connection, pull the rear facing camera off completely. It will slide out of its slot in the motherboard.
    댓글 쓰기
  12. Motorola Droid RAZR M Battery Replacement: 12 단계, 이미지 2개 중 1개 Motorola Droid RAZR M Battery Replacement: 12 단계, 이미지 2개 중 2개
    • Disconnect the snap connection in the upper right corner by prying underneath using the plastic opening tool.
    댓글 쓰기
  13. Motorola Droid RAZR M Battery Replacement: 13 단계, 이미지 3개 중 1개 Motorola Droid RAZR M Battery Replacement: 13 단계, 이미지 3개 중 2개 Motorola Droid RAZR M Battery Replacement: 13 단계, 이미지 3개 중 3개
    • By inserting the plastic opening tool between the motherboard and rear casing, lift the bottom of the motherboard from the rear casing.
    • Use your fingers to gently pull the motherboard down and out of the rear casing.
    댓글 쓰기
  14. Motorola Droid RAZR M Battery Replacement, Battery: 14 단계, 이미지 3개 중 1개 Motorola Droid RAZR M Battery Replacement, Battery: 14 단계, 이미지 3개 중 2개 Motorola Droid RAZR M Battery Replacement, Battery: 14 단계, 이미지 3개 중 3개
    • Peel back the plastic from the face of the battery.
    댓글 쓰기
  15. Motorola Droid RAZR M Battery Replacement: 15 단계, 이미지 3개 중 1개 Motorola Droid RAZR M Battery Replacement: 15 단계, 이미지 3개 중 2개 Motorola Droid RAZR M Battery Replacement: 15 단계, 이미지 3개 중 3개
    • Pull up on the plastic to lift the battery out of the rear assembly casing.
    • There is adhesive securing the battery so you will need to apply a good amount of force.
    • Hold down the left edge of the rear assembly casing as you pull the battery out.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Thomas Fenner
회원 가입일: 04/22/15
515 평판
안내서 1개를 작성함
Cal Poly, Team 15-1, Amido Spring 2015 Cal Poly, Team 15-1, Amido Spring 2015 회원
CPSU-AMIDO-S15S15G1
4 회원들
안내서 21개를 작성함
6가이드 댓글
Thank you! This phone is really well-built, and a bear to disassemble. This guide had exactly what I needed to see.
Roy Thomasson - 답글 공유
this was a rockin' guide!!! looked everywhere and here it is, and yes a bear but a cool one!
apriltanner1975 - 답글 공유
Thank You! Hope this new battery works better than the old one!
autococker13 - 답글 공유
Yeah it's kind of helpful.
Sebastian ballensky - 답글 공유
where will i get the battery for the my own phone now
Timothy - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 30
전체 시간: 9,172
