주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Moto E Battery Replacement
필요한 것
  1. Motorola Moto E  Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Motorola Moto E  Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn off the device before beginning the battery replacement.
    • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
    • You should hear a snapping sound at each corner.
    댓글 쓰기
  2. Motorola Moto E  Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Unscrew all 14- 4mm screws located on the back part of the phone using a T4 Torx bit.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
    댓글 쓰기
  3. Motorola Moto E  Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
    • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
    댓글 쓰기
  4. Motorola Moto E  Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Do not touch the connections to the battery in the red square on the picture.
    댓글 쓰기
  5. Motorola Moto E  Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Move the battery and cover away from the motherboard.
    댓글 쓰기
  6. Motorola Moto E  Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Lift gently on the battery using the metal spudger tool.
    • The battery is stuck to the plastic case with double sided tape. You should hear the battery peeling away from the cover as you are pulling on it.
    • Obtain a new battery and place it into the plastic casing using double sided tape or whatever is provided with the new battery.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 36명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Alex Craig
회원 가입일: 03/11/15
2,611 평판
안내서 5개를 작성함
Colorado Springs, Team 5-7, Panko Spring 2015 Colorado Springs, Team 5-7, Panko Spring 2015 회원
UCCS-PANKO-S15S5G7
2 회원들
안내서 15개를 작성함
7가이드 댓글
another quite superb guide from ifixit ....
I'm not surprised either as the guides on here are far and away the best available online.
keep up the good work contributors!
carol - 답글 공유
is it possible to fit Moto 2 gen battery into Moto 1 gen phone ?
Clement Santhosh - 답글 공유
This worked very well for me, many thanks!
Tony Franks - 답글 공유
which battery type or brand should we purchase????????
hridaya123.praja - 답글 공유
Excellent, clear instructions!
Gerald Griffin - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 22
지난 30일: 128
전체 시간: 79,403
