주요 콘텐츠로 건너뛰기
Motorola Moto G 2nd Generation Motherboard Replacement
Jared Geraets
Jared Geraets3 다른 기여자
최종 수정일 May 15, 2023
10 - 15 분
조정
This guide will teach you how to replace the motherboard in your Moto G, in the event that it is malfunctioning. It may take a while, since the battery and SD/SIM card reader must be removed first, but all you will need are a T5 Torx screwdriver and a plastic opening tool.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
필요한 것
도구
더보기...
  1. Motorola Moto G 2nd Generation Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Motorola Moto G 2nd Generation Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Motorola Moto G 2nd Generation Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Make sure your Moto G is turned off and that any SIM or SD cards are removed before beginning disassembly.
    • Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger.
    • Work your way down the sides to avoid cracking the rear cover.
  2. Motorola Moto G 2nd Generation Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Motorola Moto G 2nd Generation Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Motorola Moto G 2nd Generation Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the eight 4.2 mm screws at the top and bottom of the phone using a T5 Torx screwdriver.
    • Using the same screwdriver, remove the six 3.2 mm screws on the sides.
    • Remove the next layer of the phone by prying it off with your fingers.
  3. Motorola Moto G 2nd Generation Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Motorola Moto G 2nd Generation Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Motorola Moto G 2nd Generation Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using a plastic opening tool or tweezers, disconnect the SIM/SD card reader at the top of the phone.
    • Disconnect the battery connector by prying it off of the motherboard.
    • Disconnect the vibration motor by prying its connector off of the motherboard.
  4. Motorola Moto G 2nd Generation Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Motorola Moto G 2nd Generation Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Motorola Moto G 2nd Generation Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, carefully pry off the entire SIM/SD card reader component.
    • Don't worry about ripping the copper foil a little bit, it is easy to put back on.
    • When reassembling the device, do not attempt to smooth the foil down with your finger. Metal foil can become sharp if folded in a certain way, and you may be cut.
    • The battery may be removed without removing the SIM/SD card reader. Simply peel back the copper foil from the opposite end of the device, stopping just before you reach the SIM/SD card reader.
  5. Motorola Moto G 2nd Generation Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Motorola Moto G 2nd Generation Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Motorola Moto G 2nd Generation Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Peel off the two black stickers on the right side of the battery using your fingers.
    • Remove the battery by pulling the right side of it upwards.
    • The black stickers are the protruding ends of the two parallel adhesive strips which hold the battery in place. You can see the adhesive strips in the third image. Focus your effort on these regions.
    • If you did not remove the SIM/SD card reader in the previous step, you will need to carefully slide the battery ribbon cable out from under it once you have freed the battery from the adhesive strips.
  6. Motorola Moto G 2nd Generation Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 1개 Motorola Moto G 2nd Generation Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 2개 Motorola Moto G 2nd Generation Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 3개
    • Remove LCD connector by lifting the black plastic flap.
  7. Motorola Moto G 2nd Generation Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Motorola Moto G 2nd Generation Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Motorola Moto G 2nd Generation Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Using a T5 Torx screwdriver, unscrew the three 2.2 mm screws holding the motherboard in place.
  8. Motorola Moto G 2nd Generation Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Motorola Moto G 2nd Generation Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Carefully remove the motherboard.
결론
다른 30명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jared Geraets
회원 가입일: 10/01/15
655 평판
안내서 1개를 작성함
Cal Poly, Team 1-19, Maness Fall 2015 Cal Poly, Team 1-19, Maness Fall 2015 회원
CPSU-MANESS-F15S1G19
4 회원들
안내서 15개를 작성함
댓글 4개
What about Android, it comes already flashed on a new motherboard or I need to flash it myself?
marcelmaximo - 답글
Where can i buy mother board for moto g 2nd gen lte. Any idea?
kasi balaji - 답글
Please give me moto g2 motherboard
Kvasu - 답글
hi ...great guide thanks...Ihave a question Can a Motherboard from a Motorola Moto G2 XT1068 fit into a G2 XT1072 phone Thanks
Paul - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 36
전체 시간: 17,945
