주요 콘텐츠로 건너뛰기
Motorola Moto G 2nd Generation Rear Camera Replacement
stanley rosky
stanley rosky6 다른 기여자
최종 수정일 March 21, 2025
15 - 25 분
조정
In this guide, you will learn to replace the rear facing camera in your Moto G, in the event that it malfunctions or breaks. While the part itself if very easy to disconnect from the phone, getting to it requires you to remove the motherboard, which may take a while. Luckily, all you will need to complete this repair is a Torx T5 screwdriver and a plastic opening tool.
Before you begin, download the Software Fix app to backup your device and diagnose whether your problem is software or hardware related.
필요한 것
도구
더보기...
  1. Motorola Moto G 2nd Generation Rear Camera Replacement, Battery: 1 단계, 이미지 3개 중 1개 Motorola Moto G 2nd Generation Rear Camera Replacement, Battery: 1 단계, 이미지 3개 중 2개 Motorola Moto G 2nd Generation Rear Camera Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Make sure your Moto G is turned off and that any SIM or SD cards are removed before beginning disassembly.
    • Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger.
    • Work your way down the sides to avoid cracking the rear cover.
  2. Motorola Moto G 2nd Generation Rear Camera Replacement: 2 단계, 이미지 3개 중 1개 Motorola Moto G 2nd Generation Rear Camera Replacement: 2 단계, 이미지 3개 중 2개 Motorola Moto G 2nd Generation Rear Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the eight 4.2 mm screws at the top and bottom of the phone using a T5 Torx screwdriver.
    • Using the same screwdriver, remove the six 3.2 mm screws on the sides.
    • Remove the next layer of the phone by prying it off with your fingers.
  3. Motorola Moto G 2nd Generation Rear Camera Replacement: 3 단계, 이미지 3개 중 1개 Motorola Moto G 2nd Generation Rear Camera Replacement: 3 단계, 이미지 3개 중 2개 Motorola Moto G 2nd Generation Rear Camera Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using a plastic opening tool or tweezers, disconnect the SIM/SD card reader at the top of the phone.
    • Disconnect the battery connector by prying it off of the motherboard.
    • Disconnect the vibration motor by prying its connector off of the motherboard.
  4. Motorola Moto G 2nd Generation Rear Camera Replacement: 4 단계, 이미지 3개 중 1개 Motorola Moto G 2nd Generation Rear Camera Replacement: 4 단계, 이미지 3개 중 2개 Motorola Moto G 2nd Generation Rear Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, carefully pry off the entire SIM/SD card reader component.
    • Don't worry about ripping the copper foil a little bit, it is easy to put back on.
    • When reassembling the device, do not attempt to smooth the foil down with your finger. Metal foil can become sharp if folded in a certain way, and you may be cut.
    • The battery may be removed without removing the SIM/SD card reader. Simply peel back the copper foil from the opposite end of the device, stopping just before you reach the SIM/SD card reader.
  5. Motorola Moto G 2nd Generation Rear Camera Replacement: 5 단계, 이미지 3개 중 1개 Motorola Moto G 2nd Generation Rear Camera Replacement: 5 단계, 이미지 3개 중 2개 Motorola Moto G 2nd Generation Rear Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Peel off the two black stickers on the right side of the battery using your fingers.
    • Remove the battery by pulling the right side of it upwards.
    • The black stickers are the protruding ends of the two parallel adhesive strips which hold the battery in place. You can see the adhesive strips in the third image. Focus your effort on these regions.
    • If you did not remove the SIM/SD card reader in the previous step, you will need to carefully slide the battery ribbon cable out from under it once you have freed the battery from the adhesive strips.
  6. Motorola Moto G 2nd Generation Rear Camera Replacement, Motherboard: 6 단계, 이미지 3개 중 1개 Motorola Moto G 2nd Generation Rear Camera Replacement, Motherboard: 6 단계, 이미지 3개 중 2개 Motorola Moto G 2nd Generation Rear Camera Replacement, Motherboard: 6 단계, 이미지 3개 중 3개
    • Remove LCD connector by lifting the black plastic flap.
  7. Motorola Moto G 2nd Generation Rear Camera Replacement: 7 단계, 이미지 3개 중 1개 Motorola Moto G 2nd Generation Rear Camera Replacement: 7 단계, 이미지 3개 중 2개 Motorola Moto G 2nd Generation Rear Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Using a T5 Torx screwdriver, unscrew the three 2.2 mm screws holding the motherboard in place.
  8. Motorola Moto G 2nd Generation Rear Camera Replacement: 8 단계, 이미지 2개 중 1개 Motorola Moto G 2nd Generation Rear Camera Replacement: 8 단계, 이미지 2개 중 2개
    • Carefully remove the motherboard.
  9. Motorola Moto G 2nd Generation Rear Camera Replacement, Rear Camera: 9 단계, 이미지 1개 중 1개
    • The location of the rear facing camera can be seen here.
  10. Motorola Moto G 2nd Generation Rear Camera Replacement: 10 단계, 이미지 1개 중 1개
    • Flip over the motherboard.
    • Remove the tape that is covering the rear camera using your fingers.
  11. Motorola Moto G 2nd Generation Rear Camera Replacement: 11 단계, 이미지 3개 중 1개 Motorola Moto G 2nd Generation Rear Camera Replacement: 11 단계, 이미지 3개 중 2개 Motorola Moto G 2nd Generation Rear Camera Replacement: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use the prying tweezers to remove the rear facing camera connector on its right side.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
stanley rosky
회원 가입일: 10/01/15
713 평판
안내서 2개를 작성함
Cal Poly, Team 1-19, Maness Fall 2015 Cal Poly, Team 1-19, Maness Fall 2015 회원
CPSU-MANESS-F15S1G19
4 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 24
전체 시간: 3,504
